EDIT: hab mal die 2 zeilen ins startup script eingefügt @Gerd
hier nochmal das ganze log:
root@DD-WRT:/tmp# cat vpn.log
Thu Jan 1 01:00:34 1970 OpenVPN 2.3.8 mips-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Jan 16 2016
Thu Jan 1 01:00:34 1970 library versions: OpenSSL 1.0.2e 3 Dec 2015, LZO 2.09
Thu Jan 1 01:00:34 1970 WARNING: file '/tmp/openvpncl/credentials' is group or others accessible
Thu Jan 1 01:00:34 1970 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:16
Thu Jan 1 01:00:34 1970 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Jan 1 01:00:34 1970 WARNING: file '/tmp/openvpncl/client.key' is group or others accessible
Thu Jan 1 01:00:34 1970 Deprecated TLS cipher name 'DHE-RSA-AES256-GCM-SHA384', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-GCM-SHA384'
Thu Jan 1 01:00:34 1970 Deprecated TLS cipher name 'DHE-RSA-AES256-SHA256', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-CBC-SHA256'
Thu Jan 1 01:00:34 1970 Deprecated TLS cipher name 'DHE-RSA-AES128-GCM-SHA256', please use IANA name 'TLS-DHE-RSA-WITH-AES-128-GCM-SHA256'
Thu Jan 1 01:00:34 1970 Deprecated TLS cipher name 'DHE-RSA-AES128-SHA256', please use IANA name 'TLS-DHE-RSA-WITH-AES-128-CBC-SHA256'
Thu Jan 1 01:00:34 1970 Deprecated TLS cipher name 'DHE-RSA-CAMELLIA256-SHA', please use IANA name 'TLS-DHE-RSA-WITH-CAMELLIA-256-CBC-SHA'
Thu Jan 1 01:00:34 1970 Deprecated TLS cipher name 'DHE-RSA-AES256-SHA', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-CBC-SHA'
Thu Jan 1 01:00:34 1970 Deprecated TLS cipher name 'DHE-RSA-CAMELLIA128-SHA', please use IANA name 'TLS-DHE-RSA-WITH-CAMELLIA-128-CBC-SHA'
Thu Jan 1 01:00:34 1970 Deprecated TLS cipher name 'DHE-RSA-AES128-SHA', please use IANA name 'TLS-DHE-RSA-WITH-AES-128-CBC-SHA'
Thu Jan 1 01:00:35 1970 WARNING: file '/tmp/openvpncl/ta.key' is group or others accessible
Thu Jan 1 01:00:35 1970 Control Channel Authentication: using '/tmp/openvpncl/ta.key' as a OpenVPN static key file
Thu Jan 1 01:00:35 1970 Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Thu Jan 1 01:00:35 1970 Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Thu Jan 1 01:00:35 1970 Socket Buffers: R=[32767->65534] S=[32767->65534]
Thu Jan 1 01:00:35 1970 UDPv4 link local: [undef]
Thu Jan 1 01:00:35 1970 UDPv4 link remote: [AF_INET]37.48.74.75:1149
Wed Jan 20 18:29:05 2016 TLS Error: TLS key negotiation failed to occur within 120 seconds (check your network connectivity)
Wed Jan 20 18:29:05 2016 TLS Error: TLS handshake failed
Wed Jan 20 18:29:05 2016 SIGUSR1[soft,tls-error] received, process restarting
Wed Jan 20 18:29:05 2016 Restart pause, 2 second(s)
Wed Jan 20 18:29:07 2016 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Wed Jan 20 18:29:07 2016 Socket Buffers: R=[32767->65534] S=[32767->65534]
Wed Jan 20 18:29:07 2016 TCP/UDP: Preserving recently used remote address: [AF_INET]37.48.74.75:1149
Wed Jan 20 18:29:07 2016 UDPv4 link local: [undef]
Wed Jan 20 18:29:07 2016 UDPv4 link remote: [AF_INET]37.48.74.75:1149
Wed Jan 20 18:29:07 2016 TLS: Initial packet from [AF_INET]37.48.74.75:1149, sid=6ff1fbb8 e52c1edb
Wed Jan 20 18:29:07 2016 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Wed Jan 20 18:29:09 2016 VERIFY OK: depth=1, C=NZ, ST=Wellington, L=Johnsonville, O=perfect-privacy, CN=perfect-privacy, emailAddress=admin@perfect-privacy.com
Wed Jan 20 18:29:09 2016 VERIFY OK: nsCertType=SERVER
Wed Jan 20 18:29:09 2016 VERIFY OK: depth=0, C=NZ, ST=Wellington, O=perfect-privacy, CN=server, emailAddress=admin@perfect-privacy.com
Wed Jan 20 18:29:37 2016 NOTE: --mute triggered...
Wed Jan 20 18:29:37 2016 5 variation(s) on previous 3 message(s) suppressed by --mute
Wed Jan 20 18:29:37 2016 [server] Peer Connection Initiated with [AF_INET]37.48.74.75:1149
Wed Jan 20 18:29:39 2016 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Wed Jan 20 18:29:40 2016 PUSH: Received control message: 'PUSH_REPLY,ifconfig-ipv6 fdbf:1d37:bbe0:15:1:1:1:1243/112 fdbf:1d37:bbe0:15:1:1:1:1,redirect-gateway def1,sndbuf 131072,rcvbuf 131072,topology subnet,route-gateway 10.15.11.1,redirect-gateway ipv6,route-ipv6 2000::/3,ping 10,ping-restart 60,dhcp-option DNS 31.204.152.102,dhcp-option DNS 81.95.5.34,ifconfig 10.15.11.243 255.255.255.0'
Wed Jan 20 18:29:40 2016 Options error: unknown --redirect-gateway flag: ipv6
Wed Jan 20 18:29:40 2016 OPTIONS IMPORT: timers and/or timeouts modified
Wed Jan 20 18:29:40 2016 OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
Wed Jan 20 18:29:40 2016 Socket Buffers: R=[65534->65534] S=[65534->65534]
Wed Jan 20 18:29:40 2016 OPTIONS IMPORT: --ifconfig/up options modified
Wed Jan 20 18:29:40 2016 OPTIONS IMPORT: route options modified
Wed Jan 20 18:29:40 2016 OPTIONS IMPORT: route-related options modified
Wed Jan 20 18:29:40 2016 NOTE: --mute triggered...
Wed Jan 20 18:29:40 2016 1 variation(s) on previous 3 message(s) suppressed by --mute
Wed Jan 20 18:29:40 2016 TUN/TAP device tun1 opened
Wed Jan 20 18:29:40 2016 TUN/TAP TX queue length set to 100
Wed Jan 20 18:29:40 2016 do_ifconfig, tt->ipv6=1, tt->did_ifconfig_ipv6_setup=1
Wed Jan 20 18:29:40 2016 /sbin/ifconfig tun1 10.15.11.243 netmask 255.255.255.0 mtu 1500 broadcast 10.15.11.255
Wed Jan 20 18:29:40 2016 /sbin/ifconfig tun1 add fdbf:1d37:bbe0:15:1:1:1:1243/112
Wed Jan 20 18:29:40 2016 Linux ifconfig inet6 failed: external program exited with error status: 1
Wed Jan 20 18:29:40 2016 Exiting due to fatal error
root@DD-WRT:/tmp#
root@DD-WRT:/tmp#
