praxis
Hi All,
I posted the following to PP Support in hope of getting a resolution to my problem, but thought I'd post it here to get other's thoughts on the problem.
I have a somewhat uncommon setup on my PC in which I have a Killer ethernet adapter and WiFi adapter both connected to the network, and the driver suite for these adapters includes a function that allows for what ends up being a fairly rudimentary load balancing / QOS scenario. Both adapters are essentially used and are able to have the user select which process goes over which adapter. The problem this causes is that it is completely incompatible with OpenVPN TAP drivers (and as I've recently discovered Viscosity and any of it's setup options tap or tun). This has been the case with every VPN provider I have used, so the issue isn't isolated to you, and if I disable the Killer networking function and use one adapter, this of course works, but I'd preferably like to continue using the configuration I have in place at present as it's useful to allocate purely download/p2p processes that download 24/7 over the WiFi adapter at a specified throttled rate, leaving the lan adapter free of traffic for the best latency outcome for gaming. I'm not sure if you have heard of AdGuard, however I just started trialing their product, and they use something called a WFP network driver, which I'm assuming is Windows Filtering Platform, and it works fine with my setup, redirecting both adapters successfully through the WFP network driver. I'm not a programmer, so I'm not sure if there is an inherent difference with VPN connections and OpenVPN/TAP adapters and IPSEC connections, but have you encountered this issue previously (or something like it) and do you have a potential solution that could work for me? Would using a WFP network driver resolve the issue and is this even possible for something like your VPN service to use?
The functions in the Killer Control Centre are called "Advanced Stream Detect" and "Killer Doubleshot Pro". As a last resort, I'll simply just have to deal disabling this each time I want to use the VPN, or find some other way of configuring the VPN on a router with OpenVPN support that I've got and routing through that. Ideally I'd prefer to use the VPN software-based on the local PC at this stage.
Any thoughts or suggestions?
Kind Regards.
Kind Regards.
