Solved: Vuze help
BruceWayne
How to use Vuze with Windows app. Which settings in both Windows app and Vuze are required for proper functioning of torrents? Can you make a guide video.
PP Stephan
Simply connect the VPN and make sure the firewall protection is active (it is by default). Now all traffic, including Vuze, will go through the VPN.
