02.12.2017 11:32:18 Debug Debug: config connect called
02.12.2017 11:32:18 Log DisconnectReason set to NoDisconnect in connect_thread
02.12.2017 11:32:18 Log Debug: connect_thread started
02.12.2017 11:32:18 Log State Change Event - Initializing
02.12.2017 11:32:19 Log Waiting for OpenVPN.exe to get ready
02.12.2017 11:32:19 Log OpenVPN.exe ready
02.12.2017 11:32:19 Log Checking firewall and DNS leak protection settings
02.12.2017 11:32:58 Log Waiting for network to get ready
02.12.2017 11:32:59 Debug Debug: Serviceconnection connect called
02.12.2017 11:33:00 Management Connecting to management interface 127.0.0.1:11196
02.12.2017 11:33:00 Log MANAGEMENT: CMD 'state on'
02.12.2017 11:33:00 Log MANAGEMENT: CMD 'hold release'
02.12.2017 11:33:00 Log MANAGEMENT: CMD 'username 'Auth' "<Username Removed>"'
02.12.2017 11:33:01 Log MANAGEMENT: CMD 'password [...]'
02.12.2017 11:33:01 Log WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
02.12.2017 11:33:01 Log NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
02.12.2017 11:33:01 Log Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
02.12.2017 11:33:01 Log Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
02.12.2017 11:33:01 Log LZO compression initializing
02.12.2017 11:33:01 Log Control Channel MTU parms [ L:1626 D:1140 EF:110 EB:0 ET:0 EL:3 ]
02.12.2017 11:33:01 Log Data Channel MTU parms [ L:1626 D:1300 EF:126 EB:407 ET:0 EL:3 ]
02.12.2017 11:33:01 Log Fragmentation MTU parms [ L:1626 D:1300 EF:125 EB:407 ET:1 EL:3 ]
02.12.2017 11:33:01 Log Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 1,cipher AES-256-CBC,auth SHA512,keysize 256,tls-auth,key-method 2,tls-client'
02.12.2017 11:33:01 Log Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 0,cipher AES-256-CBC,auth SHA512,keysize 256,tls-auth,key-method 2,tls-server'
02.12.2017 11:33:01 Log TCP/UDP: Preserving recently used remote address: [AF_INET]82.199.134.162:1148
02.12.2017 11:33:01 Log Socket Buffers: R=[65536->65536] S=[65536->65536]
02.12.2017 11:33:01 Log UDP link local: (not bound)
02.12.2017 11:33:01 Log UDP link remote: [AF_INET]82.199.134.162:1148
02.12.2017 11:33:01 Log MANAGEMENT: >STATE:1512210781,WAIT,,,,,,
02.12.2017 11:33:01 State WAIT
02.12.2017 11:33:25 Log MANAGEMENT: >STATE:1512210805,AUTH,,,,,,
02.12.2017 11:33:25 State AUTH
02.12.2017 11:33:25 Log TLS: Initial packet from [AF_INET]82.199.134.162:1148, sid=c131e50b 8c1bfc63
02.12.2017 11:33:25 Log WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
02.12.2017 11:33:30 Log VERIFY OK: depth=1, C=CH, ST=Zug, L=Zug, O=Perfect Privacy, CN=Perfect Privacy, emailAddress=admin@perfect-privacy.com
02.12.2017 11:33:30 Log VERIFY OK: nsCertType=SERVER
02.12.2017 11:33:30 Log VERIFY OK: depth=0, C=CH, ST=Zug, O=Perfect Privacy, CN=Server_basel.perfect-privacy.com, emailAddress=admin@perfect-privacy.com
02.12.2017 11:33:31 Log Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
02.12.2017 11:33:31 Log [Server_basel.perfect-privacy.com] Peer Connection Initiated with [AF_INET]82.199.134.162:1148
02.12.2017 11:33:32 Log MANAGEMENT: >STATE:1512210812,GET_CONFIG,,,,,,
02.12.2017 11:33:32 State GET_CONFIG
02.12.2017 11:33:32 Log SENT CONTROL [Server_basel.perfect-privacy.com]: 'PUSH_REQUEST' (status=1)
02.12.2017 11:33:32 Log PUSH: Received control message: 'PUSH_REPLY,topology subnet,redirect-gateway def1,sndbuf 131072,rcvbuf 131072,comp-lzo adaptive,route-gateway 10.0.87.1,redirect-gateway ipv6,route-ipv6 2000::/3,ping 10,ping-restart 60,dhcp-option DNS 82.199.134.174,dhcp-option DNS 185.17.184.3,ifconfig-ipv6 fdbf:1d37:bbe0:0:5:7:0:1246/112 fdbf:1d37:bbe0:0:5:7:0:1,ifconfig 10.0.87.246 255.255.255.0,peer-id 6'
02.12.2017 11:33:32 Log OPTIONS IMPORT: timers and/or timeouts modified
02.12.2017 11:33:32 Log OPTIONS IMPORT: compression parms modified
02.12.2017 11:33:32 Log LZO compression initializing
02.12.2017 11:33:32 Log OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
02.12.2017 11:33:32 Log Socket Buffers: R=[65536->131072] S=[65536->131072]
02.12.2017 11:33:32 Log OPTIONS IMPORT: --ifconfig/up options modified
02.12.2017 11:33:32 Log OPTIONS IMPORT: route options modified
02.12.2017 11:33:32 Log OPTIONS IMPORT: route-related options modified
02.12.2017 11:33:32 Log OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
02.12.2017 11:33:32 Log OPTIONS IMPORT: peer-id set
02.12.2017 11:33:32 Log OPTIONS IMPORT: adjusting link_mtu to 1629
02.12.2017 11:33:32 Log Data Channel MTU parms [ L:1609 D:1300 EF:109 EB:407 ET:0 EL:3 ]
02.12.2017 11:33:32 Log Outgoing Data Channel: Cipher 'AES-256-CBC' initialized with 256 bit key
02.12.2017 11:33:32 Log Outgoing Data Channel: Using 512 bit message hash 'SHA512' for HMAC authentication
02.12.2017 11:33:32 Log Incoming Data Channel: Cipher 'AES-256-CBC' initialized with 256 bit key
02.12.2017 11:33:32 Log Incoming Data Channel: Using 512 bit message hash 'SHA512' for HMAC authentication
02.12.2017 11:33:32 Log interactive service msg_channel=0
02.12.2017 11:33:32 Log ROUTE_GATEWAY 10.0.0.138/255.255.255.0 I=5 HWADDR=08:d4:0c:67:97:7e
02.12.2017 11:33:32 Log GDG6: remote_host_ipv6=n/a
02.12.2017 11:33:32 Log NOTE: GetBestInterfaceEx returned error: Element nicht gefunden. (code=1168)
02.12.2017 11:33:32 Log ROUTE6: default_gateway=UNDEF
02.12.2017 11:33:32 Log open_tun
02.12.2017 11:33:32 Log TAP-WIN32 device [Ethernet] opened: \\.\Global\{985BF598-0395-4BFD-981E-FA3A17FF07DC}.tap
02.12.2017 11:33:32 Log TAP-Windows Driver Version 9.21
02.12.2017 11:33:32 Log TAP-Windows MTU=1500
02.12.2017 11:33:32 Log Set TAP-Windows TUN subnet mode network/local/netmask = 10.0.87.0/10.0.87.246/255.255.255.0 [SUCCEEDED]
02.12.2017 11:33:32 Log Notified TAP-Windows driver to set a DHCP IP/netmask of 10.0.87.246/255.255.255.0 on interface {985BF598-0395-4BFD-981E-FA3A17FF07DC} [DHCP-serv: 10.0.87.254, lease-time: 31536000]
02.12.2017 11:33:32 Log DHCP option string: 060852c7 86aeb911 b803
02.12.2017 11:33:32 Log Successful ARP Flush on interface [8] {985BF598-0395-4BFD-981E-FA3A17FF07DC}
02.12.2017 11:33:32 Log do_ifconfig, tt->did_ifconfig_ipv6_setup=1
02.12.2017 11:33:32 Log MANAGEMENT: >STATE:1512210812,ASSIGN_IP,,10.0.87.246,,,,,fdbf:1d37:bbe0:0:5:7:0:1246
02.12.2017 11:33:33 State ASSIGN_IP
02.12.2017 11:33:33 Log NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=8 fdbf:1d37:bbe0:0:5:7:0:1246 store=active
02.12.2017 11:33:33 Log add_route_ipv6(fdbf:1d37:bbe0:0:5:7::/112 -> fdbf:1d37:bbe0:0:5:7:0:1246 metric 0) dev Ethernet
02.12.2017 11:33:33 Log C:\Windows\system32\netsh.exe interface ipv6 add route fdbf:1d37:bbe0:0:5:7::/112 interface=8 fe80::8 store=active
02.12.2017 11:33:33 Log env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
02.12.2017 11:33:33 Log updown_v6.bat Ethernet 1500 1609 10.0.87.246 255.255.255.0 init
02.12.2017 11:33:36 Log TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
02.12.2017 11:33:36 Log Initialization Sequence Completed
02.12.2017 11:33:36 Log MANAGEMENT: >STATE:1512210816,CONNECTED,SUCCESS,10.0.87.246,82.199.134.162,1148,,,fdbf:1d37:bbe0:0:5:7:0:1246
02.12.2017 11:33:36 Log State Change Event - Running
02.12.2017 11:33:47 State CONNECTED
