Split tunneling
Discussion in 'Suggestions' started by Koraso, Aug 14, 2018.
  1. K
    Koraso New Member
    I want to request this feature which I found with. Expressvpn.
    It allows you to specify which programs you want to use the vpn connection, or which ones you don't want to use it.
    In the latter case the rest of your programs will go through the vpn.
    I found this feature very useful since you can let the application tied to your identity use your normal connection while you do your stuff through the vpn.
    Dismiss Notice
