I run multiple "leak detection" tests from several different websites to test various VPN's for leaks. When I run those tests on the previous VPN that I used, they do not show any IPv6 address. It is unknown. When I run those same tests using PP, it shows the IPv6 address of the server that I am supposed to be using (the PP one) - but it does not show my actual IPv6 address.
Ipleak.net will also show multiple PP DNS addresses. For example, if I connect to Dallas, TX - ipleak will show the DNS addresses for United Kingdom & Dallas, TX.
In both situations, I am using the exact same browser / plugins / etc, the only difference is the VPN. Can you explain why PP will show the IPv6 address of its server(s) & why this does or does not posse a risk to me?
