Thanks maze. No its working fine.
Some more questions:
A. In OpenVPN Settings the "Use system Proxy" is tappet. Is it how it should be?
B. In profile server settings "IP and DNS"/ "Pull settings" is on. Is it how it should be?
C. In profile server settings "IP and DNS"/ "No local binding" is tappet. Is it how it should be?
D. In profile server settings "Routing"/ IPv4/"Use default Route" is tappet. Is it how it should be?
E. In profile server settings "Routing"/ IPv6/"Use default Route" is tappet. (I tappet it) Is this ok?
F. In profile server settings "Authentication/Encryption"/ "Use TLS Authentication" is on. Is it how it should be?
G. In profile server settings "Advanced"/ "Allow floating server"/ is tappet. Is it how it should be?
H. In profile server settings "Advanced"/ "Persistent tun"/ is tappet. (I tappet it) Is this ok?
I. In profile server settings "Advanced"/ "Enable Custom Options"/ is tappet. Is it how it should be?
J. I have put in auth-nocache but it does not seems to work. Any ideas how to make it work?
K. If i use openVPN on my computer then it does not work on the mobile if i try to start openVPN. This is how it should be, am i right? If i´m right,. How long must i wait after i disconnected OpenVPN on my computer before i can logg in with my mobile?,
L. Do you have any more tips for making some more settings to make the mobile even more safe?
Thanks all of you for all healp in this thread and a happy christmas and a happy new year.
