Sajive Trehan
Hi Everyone
Greetings from Switzerland.
I am new to this group and New to IP v6 on Advanced Tomato Router.
I have a Linksys E2500 V3 Router running Advanced Tomato Build v 3.5 - 140 Mega VPN.
I have two VPN's setup on the OPEN VPN Clients one goes to Tor Guard and second goes to Perfect Privacy.
Both tunnels are setup and fine and I use Custom Routing to redirect each connected machine on the LAN to selectively route them on either VPN.
Perfect Privacy provides a Dynamic IP
Tor Guard has a Dedicated Public IP with selected Ports forwarded to Router Interface.
Things are fine till here.
NOW THE PROBLEM.
I want to implement an IP v6 Tunnel from Tunnelbrokers.net I have /48 and a separate /64 Allocation from them.
My ISP does NOT Provide Static IP Address and gives out Private IP's on the Internet WAN IP and they have a monopoly and have no options in our area.
So the only available IP for the Tunnel is the dedicated one from Torguard or the dynamic one from Perfect Privacy.
Perfect Privacy supports IP v6.
I have done whatever i could but am UNABLE to set up the tunnel.
Tunnelbroker customer support says some problem is with Protocol 41.
Also, I am unable to set up a DHCP v6 Server on the Tomato router so that it can distribute Machines on the Lan with an IP v6 with a prefix of Tunnelbrokers. At the moment it is giving out Local v6 IP's.
Can any from you help please?
I await your answer.
Regards
Sajive Trehan
Zurich - Switzerland.
NOW THE PROBLEM.
Regards
Sajive Trehan
