Hello. I am trying to setup port forwarding, using the Linux .deb VPN manager.
I opened the port on my local machine (when using the nmap -p command on my localhost or local IP, it says the port is open). I then asked for a port forwarding on the server I connect to. I have a source port to which I connect, using amsterdam.perfect-privacy.com, and it should redirect to my local port.
But it just times out. I used my perfect privacy login and pass, then tried again with my ssh login and password.
I cannot find a clear guide on how to setup port forwarding, could anybody explain it to me?
I also would like to setup port forwarding but using an openVPN configuration. The reason is that the linux client doesn't start automatically, and I don't want to wait 2 years until an update comes out that can do it. Could anyoe either point me to a tutorial or explain how one would proceed to setup port forwarding using Perfect Privacy and an openVPN CLI configuration?
Your service is pretty cool and I like it, but it lacks a LOT of documentation and tutorials. ^^
If you answer my questions, I will update the OP and format a HOW TO for future reference.
Thank you very much for your support!
