Custom settings-presets
Discussion in 'Suggestions' started by LAZ, Nov 10, 2017.
  1. L
    LAZ New Member
    Any chance you could implement custom options-presets at some point? That way the user could quickly swap settings to fit the use scenario. Wouldn't have to work while being connected to a server imo.
    BTW, thanks for providing a great VPN-service!
  2. PP Stephan
    PP Stephan Staff Member
    Thank you for your input. That isn't a bad idea, we will consider it.
    Dismiss Notice
