ASUS Merlin ROG GT-RX11000 PRO // no connection
umido
Hallo Community,
ich weiss es gibt schon viele Anleitungen zu dem Thema, jedoch habe ich schon alles probiert und werde nicht schlauer daraus.
Mein Router ist der ASUS Merlin ROG GT-RX11000 PRO mit der Firmware 004_388.5_0.
Nach dem Import der .ovpn datei bekomme ich keine aktive Verbindung.
Es heisst nur, Connecting...
Habe das aktuellste Tut von @PapaBear2 benutzt.
Jemand eine idee?
Log File:
Jan 5 13:27:04 rc_service: httpd 18245:notify_rc start_vpnclient3
Jan 5 13:27:04 ovpn-client3[27707]: WARNING: You have specified redirect-gateway and redirect-private at the same time (or the same option multiple times). This is not well supported and may lead to unexpected results
Jan 5 13:27:04 ovpn-client3[27707]: Note: --cipher is not set. OpenVPN versions before 2.5 defaulted to BF-CBC as fallback when cipher negotiation failed in this case. If you need this fallback please add '--data-ciphers-fallback BF-CBC' to your configuration and/or add BF-CBC to --data-ciphers.
Jan 5 13:27:04 ovpn-client3[27707]: Current Parameter Settings:
Jan 5 13:27:04 ovpn-client3[27707]: config = 'config.ovpn'
Jan 5 13:27:04 ovpn-client3[27707]: mode = 0
Jan 5 13:27:04 ovpn-client3[27707]: persist_config = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: persist_mode = 1
Jan 5 13:27:04 ovpn-client3[27707]: show_ciphers = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: show_digests = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: show_engines = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: genkey = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: genkey_filename = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: key_pass_file = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: show_tls_ciphers = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: connect_retry_max = 15
Jan 5 13:27:04 ovpn-client3[27707]: Connection profiles [0]:
Jan 5 13:27:04 ovpn-client3[27707]: proto = udp
Jan 5 13:27:04 ovpn-client3[27707]: local = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: local_port = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: remote = '162.245.206.242'
Jan 5 13:27:04 ovpn-client3[27707]: remote_port = '1151'
Jan 5 13:27:04 ovpn-client3[27707]: remote_float = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: bind_defined = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: bind_local = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: bind_ipv6_only = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: connect_retry_seconds = 1
Jan 5 13:27:04 ovpn-client3[27707]: connect_timeout = 120
Jan 5 13:27:04 ovpn-client3[27707]: socks_proxy_server = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: socks_proxy_port = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: tun_mtu = 1500
Jan 5 13:27:04 ovpn-client3[27707]: tun_mtu_defined = ENABLED
Jan 5 13:27:04 ovpn-client3[27707]: link_mtu = 1500
Jan 5 13:27:04 ovpn-client3[27707]: link_mtu_defined = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: tun_mtu_extra = 0
Jan 5 13:27:04 ovpn-client3[27707]: tun_mtu_extra_defined = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: tls_mtu = 1250
Jan 5 13:27:04 ovpn-client3[27707]: mtu_discover_type = -1
Jan 5 13:27:04 ovpn-client3[27707]: fragment = 1300
Jan 5 13:27:04 ovpn-client3[27707]: mssfix = 1300
Jan 5 13:27:04 ovpn-client3[27707]: mssfix_encap = ENABLED
Jan 5 13:27:04 ovpn-client3[27707]: mssfix_fixed = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: explicit_exit_notification = 0
Jan 5 13:27:04 ovpn-client3[27707]: tls_auth_file = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: key_direction = not set
Jan 5 13:27:04 ovpn-client3[27707]: tls_crypt_file = '[INLINE]'
Jan 5 13:27:04 ovpn-client3[27707]: tls_crypt_v2_file = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: Connection profiles END
Jan 5 13:27:04 ovpn-client3[27707]: remote_random = ENABLED
Jan 5 13:27:04 ovpn-client3[27707]: ipchange = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: dev = 'tun13'
Jan 5 13:27:04 ovpn-client3[27707]: dev_type = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: dev_node = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: lladdr = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: topology = 1
Jan 5 13:27:04 ovpn-client3[27707]: ifconfig_local = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: ifconfig_remote_netmask = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: ifconfig_noexec = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: ifconfig_nowarn = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: ifconfig_ipv6_local = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: ifconfig_ipv6_netbits = 0
Jan 5 13:27:04 ovpn-client3[27707]: ifconfig_ipv6_remote = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: shaper = 0
Jan 5 13:27:04 ovpn-client3[27707]: mtu_test = 0
Jan 5 13:27:04 ovpn-client3[27707]: mlock = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: keepalive_ping = 0
Jan 5 13:27:04 ovpn-client3[27707]: keepalive_timeout = 0
Jan 5 13:27:04 ovpn-client3[27707]: inactivity_timeout = 604800
Jan 5 13:27:04 ovpn-client3[27707]: session_timeout = 0
Jan 5 13:27:04 ovpn-client3[27707]: inactivity_minimum_bytes = 0
Jan 5 13:27:04 ovpn-client3[27707]: ping_send_timeout = 5
Jan 5 13:27:04 ovpn-client3[27707]: ping_rec_timeout = 120
Jan 5 13:27:04 ovpn-client3[27707]: ping_rec_timeout_action = 2
Jan 5 13:27:04 ovpn-client3[27707]: ping_timer_remote = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: remap_sigusr1 = 0
Jan 5 13:27:04 ovpn-client3[27707]: persist_tun = ENABLED
Jan 5 13:27:04 ovpn-client3[27707]: persist_local_ip = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: persist_remote_ip = ENABLED
Jan 5 13:27:04 ovpn-client3[27707]: persist_key = ENABLED
Jan 5 13:27:04 ovpn-client3[27707]: passtos = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: resolve_retry_seconds = 60
Jan 5 13:27:04 ovpn-client3[27707]: resolve_in_advance = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: username = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: groupname = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: chroot_dir = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: cd_dir = '/etc/openvpn/client3'
Jan 5 13:27:04 ovpn-client3[27707]: writepid = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: up_script = 'ovpn-up 3 client'
Jan 5 13:27:04 ovpn-client3[27707]: down_script = 'ovpn-down 3 client'
Jan 5 13:27:04 ovpn-client3[27707]: down_pre = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: up_restart = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: up_delay = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: daemon = ENABLED
Jan 5 13:27:04 ovpn-client3[27707]: log = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: suppress_timestamps = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: machine_readable_output = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: nice = 0
Jan 5 13:27:04 ovpn-client3[27707]: verbosity = 4
Jan 5 13:27:04 ovpn-client3[27707]: mute = 0
Jan 5 13:27:04 ovpn-client3[27707]: status_file = 'status'
Jan 5 13:27:04 ovpn-client3[27707]: status_file_version = 2
Jan 5 13:27:04 ovpn-client3[27707]: status_file_update_freq = 5
Jan 5 13:27:04 ovpn-client3[27707]: occ = ENABLED
Jan 5 13:27:04 ovpn-client3[27707]: rcvbuf = 0
Jan 5 13:27:04 ovpn-client3[27707]: sndbuf = 0
Jan 5 13:27:04 ovpn-client3[27707]: mark = 0
Jan 5 13:27:04 ovpn-client3[27707]: sockflags = 0
Jan 5 13:27:04 ovpn-client3[27707]: fast_io = ENABLED
Jan 5 13:27:04 ovpn-client3[27707]: comp.alg = 0
Jan 5 13:27:04 ovpn-client3[27707]: comp.flags = 24
Jan 5 13:27:04 ovpn-client3[27707]: route_script = 'ovpn-route-up'
Jan 5 13:27:04 ovpn-client3[27707]: route_default_gateway = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: route_default_metric = 0
Jan 5 13:27:04 ovpn-client3[27707]: route_noexec = ENABLED
Jan 5 13:27:04 ovpn-client3[27707]: route_delay = 2
Jan 5 13:27:04 ovpn-client3[27707]: route_delay_window = 30
Jan 5 13:27:04 ovpn-client3[27707]: route_delay_defined = ENABLED
Jan 5 13:27:04 ovpn-client3[27707]: route_nopull = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: route_gateway_via_dhcp = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: allow_pull_fqdn = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: Pull filters:
Jan 5 13:27:04 ovpn-client3[27707]: ignore "ifconfig-ipv6"
Jan 5 13:27:04 ovpn-client3[27707]: ignore "route-ipv6"
Jan 5 13:27:04 ovpn-client3[27707]: [redirect_default_gateway local=0]
Jan 5 13:27:04 ovpn-client3[27707]: management_addr = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: management_port = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: management_user_pass = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: management_log_history_cache = 250
Jan 5 13:27:04 ovpn-client3[27707]: management_echo_buffer_size = 100
Jan 5 13:27:04 ovpn-client3[27707]: management_client_user = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: management_client_group = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: management_flags = 0
Jan 5 13:27:04 ovpn-client3[27707]: shared_secret_file = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: ciphername = 'BF-CBC'
Jan 5 13:27:04 ovpn-client3[27707]: ncp_ciphers = 'AES-128-CBC'
Jan 5 13:27:04 ovpn-client3[27707]: authname = 'SHA512'
Jan 5 13:27:04 ovpn-client3[27707]: engine = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: replay = ENABLED
Jan 5 13:27:04 ovpn-client3[27707]: mute_replay_warnings = ENABLED
Jan 5 13:27:04 ovpn-client3[27707]: replay_window = 64
Jan 5 13:27:04 ovpn-client3[27707]: replay_time = 15
Jan 5 13:27:04 ovpn-client3[27707]: packet_id_file = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: test_crypto = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: tls_server = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: tls_client = ENABLED
Jan 5 13:27:04 ovpn-client3[27707]: ca_file = 'ca.crt'
Jan 5 13:27:04 ovpn-client3[27707]: ca_path = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: dh_file = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: cert_file = 'client.crt'
Jan 5 13:27:04 ovpn-client3[27707]: extra_certs_file = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: priv_key_file = 'client.key'
Jan 5 13:27:04 ovpn-client3[27707]: pkcs12_file = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: cipher_list = 'TLS_CHACHA20_POLY1305_SHA256:TLS-DHE-RSA-WITH-AES-256-GCM-SHA384:TLS-DHE-RSA-WITH-AES-256-CBC-SHA:TLS-DHE-RSA-WITH-AES-128-GCM-SHA256:TLS-DHE-RSA-WITH-AES-128-CBC-SHA:TLS_AES_256_GCM_SHA384:TLS-RSA-WITH-AES-256-CBC-SHA'
Jan 5 13:27:04 ovpn-client3[27707]: cipher_list_tls13 = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: tls_cert_profile = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: tls_verify = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: tls_export_cert = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: verify_x509_type = 0
Jan 5 13:27:04 ovpn-client3[27707]: verify_x509_name = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: crl_file = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: ns_cert_type = 0
Jan 5 13:27:04 ovpn-client3[27707]: remote_cert_ku = 65535
Jan 5 13:27:04 ovpn-client3[27707]: remote_cert_ku = 0
Jan 5 13:27:04 ovpn-client3[27707]: remote_cert_eku = 'TLS Web Server Authentication'
Jan 5 13:27:04 ovpn-client3[27707]: ssl_flags = 192
Jan 5 13:27:04 ovpn-client3[27707]: tls_timeout = 5
Jan 5 13:27:04 ovpn-client3[27707]: renegotiate_bytes = -1
Jan 5 13:27:04 ovpn-client3[27707]: renegotiate_packets = 0
Jan 5 13:27:04 ovpn-client3[27707]: renegotiate_seconds = 3600
Jan 5 13:27:04 ovpn-client3[27707]: handshake_window = 120
Jan 5 13:27:04 ovpn-client3[27707]: transition_window = 3600
Jan 5 13:27:04 ovpn-client3[27707]: single_session = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: push_peer_info = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: tls_exit = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: tls_crypt_v2_metadata = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: server_network = 0.0.0.0
Jan 5 13:27:04 ovpn-client3[27707]: server_netmask = 0.0.0.0
Jan 5 13:27:04 ovpn-client3[27707]: server_network_ipv6 = ::
Jan 5 13:27:04 ovpn-client3[27707]: server_netbits_ipv6 = 0
Jan 5 13:27:04 ovpn-client3[27707]: server_bridge_ip = 0.0.0.0
Jan 5 13:27:04 ovpn-client3[27707]: server_bridge_netmask = 0.0.0.0
Jan 5 13:27:04 ovpn-client3[27707]: server_bridge_pool_start = 0.0.0.0
Jan 5 13:27:04 ovpn-client3[27707]: server_bridge_pool_end = 0.0.0.0
Jan 5 13:27:04 ovpn-client3[27707]: ifconfig_pool_defined = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: ifconfig_pool_start = 0.0.0.0
Jan 5 13:27:04 ovpn-client3[27707]: ifconfig_pool_end = 0.0.0.0
Jan 5 13:27:04 ovpn-client3[27707]: ifconfig_pool_netmask = 0.0.0.0
Jan 5 13:27:04 ovpn-client3[27707]: ifconfig_pool_persist_filename = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: ifconfig_pool_persist_refresh_freq = 600
Jan 5 13:27:04 ovpn-client3[27707]: ifconfig_ipv6_pool_defined = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: ifconfig_ipv6_pool_base = ::
Jan 5 13:27:04 ovpn-client3[27707]: ifconfig_ipv6_pool_netbits = 0
Jan 5 13:27:04 ovpn-client3[27707]: n_bcast_buf = 256
Jan 5 13:27:04 ovpn-client3[27707]: tcp_queue_limit = 64
Jan 5 13:27:04 ovpn-client3[27707]: real_hash_size = 256
Jan 5 13:27:04 ovpn-client3[27707]: virtual_hash_size = 256
Jan 5 13:27:04 ovpn-client3[27707]: client_connect_script = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: learn_address_script = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: client_disconnect_script = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: client_crresponse_script = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: client_config_dir = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: ccd_exclusive = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: tmp_dir = '/tmp'
Jan 5 13:27:04 ovpn-client3[27707]: push_ifconfig_defined = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: push_ifconfig_local = 0.0.0.0
Jan 5 13:27:04 ovpn-client3[27707]: push_ifconfig_remote_netmask = 0.0.0.0
Jan 5 13:27:04 ovpn-client3[27707]: push_ifconfig_ipv6_defined = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: push_ifconfig_ipv6_local = ::/0
Jan 5 13:27:04 ovpn-client3[27707]: push_ifconfig_ipv6_remote = ::
Jan 5 13:27:04 ovpn-client3[27707]: enable_c2c = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: duplicate_cn = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: cf_max = 0
Jan 5 13:27:04 ovpn-client3[27707]: cf_per = 0
Jan 5 13:27:04 ovpn-client3[27707]: cf_initial_max = 100
Jan 5 13:27:04 ovpn-client3[27707]: cf_initial_per = 10
Jan 5 13:27:04 ovpn-client3[27707]: max_clients = 1024
Jan 5 13:27:04 ovpn-client3[27707]: max_routes_per_client = 256
Jan 5 13:27:04 ovpn-client3[27707]: auth_user_pass_verify_script = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: auth_user_pass_verify_script_via_file = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: auth_token_generate = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: auth_token_lifetime = 0
Jan 5 13:27:04 ovpn-client3[27707]: auth_token_secret_file = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: port_share_host = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: port_share_port = '[UNDEF]'
Jan 5 13:27:04 ovpn-client3[27707]: vlan_tagging = DISABLED
Jan 5 13:27:04 ovpn-client3[27707]: vlan_accept = all
Jan 5 13:27:04 ovpn-client3[27707]: vlan_pvid = 1
Jan 5 13:27:04 ovpn-client3[27707]: client = ENABLED
Jan 5 13:27:04 ovpn-client3[27707]: pull = ENABLED
Jan 5 13:27:04 ovpn-client3[27707]: auth_user_pass_file = 'auth'
Jan 5 13:27:04 ovpn-client3[27707]: OpenVPN 2.6.8 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Jan 5 13:27:04 ovpn-client3[27707]: library versions: OpenSSL 1.1.1w 11 Sep 2023, LZO 2.10
Jan 5 13:27:04 ovpn-client3[27708]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Jan 5 13:27:04 ovpn-client3[27708]: No valid translation found for TLS cipher 'TLS_CHACHA20_POLY1305_SHA256'
Jan 5 13:27:04 ovpn-client3[27708]: No valid translation found for TLS cipher 'TLS_AES_256_GCM_SHA384'
Jan 5 13:27:04 ovpn-client3[27708]: Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
Jan 5 13:27:04 ovpn-client3[27708]: Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
Jan 5 13:27:04 ovpn-client3[27708]: Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
Jan 5 13:27:04 ovpn-client3[27708]: Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
Jan 5 13:27:04 ovpn-client3[27708]: WARNING: if you use --mssfix and --fragment, you should use the "mtu" flag for both or none of of them.
Jan 5 13:27:04 ovpn-client3[27708]: Control Channel MTU parms [ mss_fix:0 max_frag:0 tun_mtu:1250 tun_max_mtu:0 headroom:126 payload:1600 tailroom:126 ET:0 ]
Jan 5 13:27:04 ovpn-client3[27708]: Data Channel MTU parms [ mss_fix:0 max_frag:0 tun_mtu:1500 tun_max_mtu:1600 headroom:136 payload:1768 tailroom:562 ET:0 ]
Jan 5 13:27:04 ovpn-client3[27708]: Fragmentation MTU parms [ mss_fix:1139 max_frag:1227 tun_mtu:1500 tun_max_mtu:1600 headroom:136 payload:1768 tailroom:562 ET:0 ]
Jan 5 13:27:04 ovpn-client3[27708]: TCP/UDP: Preserving recently used remote address: [AF_INET]162.245.206.242:1151
Jan 5 13:27:04 ovpn-client3[27708]: Socket Buffers: R=[524288->524288] S=[524288->524288]
Jan 5 13:27:04 ovpn-client3[27708]: UDPv4 link local: (not bound)
Jan 5 13:27:04 ovpn-client3[27708]: UDPv4 link remote: [AF_INET]162.245.206.242:1151
Jan 5 13:27:13 rc_service: watchdog 2513:notify_rc start_stubbyasus.jpgasus.jpgasus.jpg
Deine Fehler laut Log:
Bitte setze unter "Benutzerdefinierte Konfiguration"
ein und "Anwenden". Dann sollte es funktionieren!
Danke fuer die Antwort.
Habe gehofft du siehst mein Thread.
Habe es unter "Benutzerdefinierte Konfiguration" eingetragen.
Bekomme weiterhin aber keine Verbindung.
Zusaetzlich zum Logfile habe ich mal die komplette "Benutzerdefinierte Konfiguration" gepostet.
OpenVPN Version ist 2.6.8.
Hast du noch eine Idee?
DANKE!!!
hand-window 120
inactive 604800
mute-replay-warnings
persist-remote-ip
ping 5
ping-restart 120
redirect-gateway def1
remote-random
script-security 2
tls-cipher TLS_CHACHA20_POLY1305_SHA256:TLS-DHE-RSA-WITH-AES-256-GCM-SHA384:TLS-DHE-RSA-WITH-AES-256-CBC-SHA:TLS-DHE-RSA-WITH-AES-128-GCM-SHA256:TLS-DHE-RSA-WITH-AES-128-CBC-SHA:TLS_AES_256_GCM_SHA384:TLS-RSA-WITH-AES-256-CBC-SHA
tls-timeout 5
route-delay 2
resolv-retry 60
route-method exe
tun-mtu 1500
fragment 1300
mssfix
data-ciphers AES-128-CBC
remote-cert-tls server
pull-filter ignore ifconfig-ipv6
pull-filter ignore route-ipv6
Jan 6 12:43:43 rc_service: watchdog 2513:notify_rc start_stubby
Jan 6 12:44:10 rc_service: httpd 18245:notify_rc start_vpnclient3
Jan 6 12:44:10 ovpn-client3[2804]: WARNING: You have specified redirect-gateway and redirect-private at the same time (or the same option multiple times). This is not well supported and may lead to unexpected results
Jan 6 12:44:10 ovpn-client3[2804]: Current Parameter Settings:
Jan 6 12:44:10 ovpn-client3[2804]: config = 'config.ovpn'
Jan 6 12:44:10 ovpn-client3[2804]: mode = 0
Jan 6 12:44:10 ovpn-client3[2804]: persist_config = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: persist_mode = 1
Jan 6 12:44:10 ovpn-client3[2804]: show_ciphers = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: show_digests = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: show_engines = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: genkey = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: genkey_filename = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: key_pass_file = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: show_tls_ciphers = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: connect_retry_max = 15
Jan 6 12:44:10 ovpn-client3[2804]: Connection profiles [0]:
Jan 6 12:44:10 ovpn-client3[2804]: proto = udp
Jan 6 12:44:10 ovpn-client3[2804]: local = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: local_port = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: remote = '162.245.206.242'
Jan 6 12:44:10 ovpn-client3[2804]: remote_port = '1151'
Jan 6 12:44:10 ovpn-client3[2804]: remote_float = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: bind_defined = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: bind_local = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: bind_ipv6_only = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: connect_retry_seconds = 1
Jan 6 12:44:10 ovpn-client3[2804]: connect_timeout = 120
Jan 6 12:44:10 ovpn-client3[2804]: socks_proxy_server = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: socks_proxy_port = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: tun_mtu = 1500
Jan 6 12:44:10 ovpn-client3[2804]: tun_mtu_defined = ENABLED
Jan 6 12:44:10 ovpn-client3[2804]: link_mtu = 1500
Jan 6 12:44:10 ovpn-client3[2804]: link_mtu_defined = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: tun_mtu_extra = 0
Jan 6 12:44:10 ovpn-client3[2804]: tun_mtu_extra_defined = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: tls_mtu = 1250
Jan 6 12:44:10 ovpn-client3[2804]: mtu_discover_type = -1
Jan 6 12:44:10 ovpn-client3[2804]: fragment = 1300
Jan 6 12:44:10 ovpn-client3[2804]: mssfix = 1300
Jan 6 12:44:10 ovpn-client3[2804]: mssfix_encap = ENABLED
Jan 6 12:44:10 ovpn-client3[2804]: mssfix_fixed = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: explicit_exit_notification = 0
Jan 6 12:44:10 ovpn-client3[2804]: tls_auth_file = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: key_direction = not set
Jan 6 12:44:10 ovpn-client3[2804]: tls_crypt_file = '[INLINE]'
Jan 6 12:44:10 ovpn-client3[2804]: tls_crypt_v2_file = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: Connection profiles END
Jan 6 12:44:10 ovpn-client3[2804]: remote_random = ENABLED
Jan 6 12:44:10 ovpn-client3[2804]: ipchange = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: dev = 'tun13'
Jan 6 12:44:10 ovpn-client3[2804]: dev_type = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: dev_node = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: lladdr = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: topology = 1
Jan 6 12:44:10 ovpn-client3[2804]: ifconfig_local = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: ifconfig_remote_netmask = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: ifconfig_noexec = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: ifconfig_nowarn = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: ifconfig_ipv6_local = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: ifconfig_ipv6_netbits = 0
Jan 6 12:44:10 ovpn-client3[2804]: ifconfig_ipv6_remote = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: shaper = 0
Jan 6 12:44:10 ovpn-client3[2804]: mtu_test = 0
Jan 6 12:44:10 ovpn-client3[2804]: mlock = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: keepalive_ping = 0
Jan 6 12:44:10 ovpn-client3[2804]: keepalive_timeout = 0
Jan 6 12:44:10 ovpn-client3[2804]: inactivity_timeout = 604800
Jan 6 12:44:10 ovpn-client3[2804]: session_timeout = 0
Jan 6 12:44:10 ovpn-client3[2804]: inactivity_minimum_bytes = 0
Jan 6 12:44:10 ovpn-client3[2804]: ping_send_timeout = 5
Jan 6 12:44:10 ovpn-client3[2804]: ping_rec_timeout = 120
Jan 6 12:44:10 ovpn-client3[2804]: ping_rec_timeout_action = 2
Jan 6 12:44:10 ovpn-client3[2804]: ping_timer_remote = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: remap_sigusr1 = 0
Jan 6 12:44:10 ovpn-client3[2804]: persist_tun = ENABLED
Jan 6 12:44:10 ovpn-client3[2804]: persist_local_ip = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: persist_remote_ip = ENABLED
Jan 6 12:44:10 ovpn-client3[2804]: persist_key = ENABLED
Jan 6 12:44:10 ovpn-client3[2804]: passtos = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: resolve_retry_seconds = 60
Jan 6 12:44:10 ovpn-client3[2804]: resolve_in_advance = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: username = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: groupname = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: chroot_dir = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: cd_dir = '/etc/openvpn/client3'
Jan 6 12:44:10 ovpn-client3[2804]: writepid = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: up_script = 'ovpn-up 3 client'
Jan 6 12:44:10 ovpn-client3[2804]: down_script = 'ovpn-down 3 client'
Jan 6 12:44:10 ovpn-client3[2804]: down_pre = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: up_restart = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: up_delay = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: daemon = ENABLED
Jan 6 12:44:10 ovpn-client3[2804]: log = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: suppress_timestamps = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: machine_readable_output = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: nice = 0
Jan 6 12:44:10 ovpn-client3[2804]: verbosity = 4
Jan 6 12:44:10 ovpn-client3[2804]: mute = 0
Jan 6 12:44:10 ovpn-client3[2804]: status_file = 'status'
Jan 6 12:44:10 ovpn-client3[2804]: status_file_version = 2
Jan 6 12:44:10 ovpn-client3[2804]: status_file_update_freq = 5
Jan 6 12:44:10 ovpn-client3[2804]: occ = ENABLED
Jan 6 12:44:10 ovpn-client3[2804]: rcvbuf = 0
Jan 6 12:44:10 ovpn-client3[2804]: sndbuf = 0
Jan 6 12:44:10 ovpn-client3[2804]: mark = 0
Jan 6 12:44:10 ovpn-client3[2804]: sockflags = 0
Jan 6 12:44:10 ovpn-client3[2804]: fast_io = ENABLED
Jan 6 12:44:10 ovpn-client3[2804]: comp.alg = 0
Jan 6 12:44:10 ovpn-client3[2804]: comp.flags = 24
Jan 6 12:44:10 ovpn-client3[2804]: route_script = 'ovpn-route-up'
Jan 6 12:44:10 ovpn-client3[2804]: route_default_gateway = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: route_default_metric = 0
Jan 6 12:44:10 ovpn-client3[2804]: route_noexec = ENABLED
Jan 6 12:44:10 ovpn-client3[2804]: route_delay = 2
Jan 6 12:44:10 ovpn-client3[2804]: route_delay_window = 30
Jan 6 12:44:10 ovpn-client3[2804]: route_delay_defined = ENABLED
Jan 6 12:44:10 ovpn-client3[2804]: route_nopull = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: route_gateway_via_dhcp = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: allow_pull_fqdn = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: Pull filters:
Jan 6 12:44:10 ovpn-client3[2804]: ignore "ifconfig-ipv6"
Jan 6 12:44:10 ovpn-client3[2804]: ignore "route-ipv6"
Jan 6 12:44:10 ovpn-client3[2804]: [redirect_default_gateway local=0]
Jan 6 12:44:10 ovpn-client3[2804]: management_addr = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: management_port = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: management_user_pass = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: management_log_history_cache = 250
Jan 6 12:44:10 ovpn-client3[2804]: management_echo_buffer_size = 100
Jan 6 12:44:10 ovpn-client3[2804]: management_client_user = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: management_client_group = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: management_flags = 0
Jan 6 12:44:10 ovpn-client3[2804]: shared_secret_file = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: ciphername = 'BF-CBC'
Jan 6 12:44:10 ovpn-client3[2804]: ncp_ciphers = 'AES-128-CBC'
Jan 6 12:44:10 ovpn-client3[2804]: authname = 'SHA512'
Jan 6 12:44:10 ovpn-client3[2804]: engine = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: replay = ENABLED
Jan 6 12:44:10 ovpn-client3[2804]: mute_replay_warnings = ENABLED
Jan 6 12:44:10 ovpn-client3[2804]: replay_window = 64
Jan 6 12:44:10 ovpn-client3[2804]: replay_time = 15
Jan 6 12:44:10 ovpn-client3[2804]: packet_id_file = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: test_crypto = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: tls_server = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: tls_client = ENABLED
Jan 6 12:44:10 ovpn-client3[2804]: ca_file = 'ca.crt'
Jan 6 12:44:10 ovpn-client3[2804]: ca_path = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: dh_file = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: cert_file = 'client.crt'
Jan 6 12:44:10 ovpn-client3[2804]: extra_certs_file = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: priv_key_file = 'client.key'
Jan 6 12:44:10 ovpn-client3[2804]: pkcs12_file = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: cipher_list = 'TLS_CHACHA20_POLY1305_SHA256:TLS-DHE-RSA-WITH-AES-256-GCM-SHA384:TLS-DHE-RSA-WITH-AES-256-CBC-SHA:TLS-DHE-RSA-WITH-AES-128-GCM-SHA256:TLS-DHE-RSA-WITH-AES-128-CBC-SHA:TLS_AES_256_GCM_SHA384:TLS-RSA-WITH-AES-256-CBC-SHA'
Jan 6 12:44:10 ovpn-client3[2804]: cipher_list_tls13 = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: tls_cert_profile = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: tls_verify = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: tls_export_cert = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: verify_x509_type = 0
Jan 6 12:44:10 ovpn-client3[2804]: verify_x509_name = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: crl_file = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: ns_cert_type = 0
Jan 6 12:44:10 ovpn-client3[2804]: remote_cert_ku = 65535
Jan 6 12:44:10 ovpn-client3[2804]: remote_cert_ku = 0
Jan 6 12:44:10 ovpn-client3[2804]: remote_cert_eku = 'TLS Web Server Authentication'
Jan 6 12:44:10 ovpn-client3[2804]: ssl_flags = 192
Jan 6 12:44:10 ovpn-client3[2804]: tls_timeout = 5
Jan 6 12:44:10 ovpn-client3[2804]: renegotiate_bytes = -1
Jan 6 12:44:10 ovpn-client3[2804]: renegotiate_packets = 0
Jan 6 12:44:10 ovpn-client3[2804]: renegotiate_seconds = 3600
Jan 6 12:44:10 ovpn-client3[2804]: handshake_window = 120
Jan 6 12:44:10 ovpn-client3[2804]: transition_window = 3600
Jan 6 12:44:10 ovpn-client3[2804]: single_session = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: push_peer_info = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: tls_exit = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: tls_crypt_v2_metadata = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: server_network = 0.0.0.0
Jan 6 12:44:10 ovpn-client3[2804]: server_netmask = 0.0.0.0
Jan 6 12:44:10 ovpn-client3[2804]: server_network_ipv6 = ::
Jan 6 12:44:10 ovpn-client3[2804]: server_netbits_ipv6 = 0
Jan 6 12:44:10 ovpn-client3[2804]: server_bridge_ip = 0.0.0.0
Jan 6 12:44:10 ovpn-client3[2804]: server_bridge_netmask = 0.0.0.0
Jan 6 12:44:10 ovpn-client3[2804]: server_bridge_pool_start = 0.0.0.0
Jan 6 12:44:10 ovpn-client3[2804]: server_bridge_pool_end = 0.0.0.0
Jan 6 12:44:10 ovpn-client3[2804]: ifconfig_pool_defined = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: ifconfig_pool_start = 0.0.0.0
Jan 6 12:44:10 ovpn-client3[2804]: ifconfig_pool_end = 0.0.0.0
Jan 6 12:44:10 ovpn-client3[2804]: ifconfig_pool_netmask = 0.0.0.0
Jan 6 12:44:10 ovpn-client3[2804]: ifconfig_pool_persist_filename = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: ifconfig_pool_persist_refresh_freq = 600
Jan 6 12:44:10 ovpn-client3[2804]: ifconfig_ipv6_pool_defined = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: ifconfig_ipv6_pool_base = ::
Jan 6 12:44:10 ovpn-client3[2804]: ifconfig_ipv6_pool_netbits = 0
Jan 6 12:44:10 ovpn-client3[2804]: n_bcast_buf = 256
Jan 6 12:44:10 ovpn-client3[2804]: tcp_queue_limit = 64
Jan 6 12:44:10 ovpn-client3[2804]: real_hash_size = 256
Jan 6 12:44:10 ovpn-client3[2804]: virtual_hash_size = 256
Jan 6 12:44:10 ovpn-client3[2804]: client_connect_script = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: learn_address_script = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: client_disconnect_script = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: client_crresponse_script = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: client_config_dir = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: ccd_exclusive = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: tmp_dir = '/tmp'
Jan 6 12:44:10 ovpn-client3[2804]: push_ifconfig_defined = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: push_ifconfig_local = 0.0.0.0
Jan 6 12:44:10 ovpn-client3[2804]: push_ifconfig_remote_netmask = 0.0.0.0
Jan 6 12:44:10 ovpn-client3[2804]: push_ifconfig_ipv6_defined = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: push_ifconfig_ipv6_local = ::/0
Jan 6 12:44:10 ovpn-client3[2804]: push_ifconfig_ipv6_remote = ::
Jan 6 12:44:10 ovpn-client3[2804]: enable_c2c = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: duplicate_cn = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: cf_max = 0
Jan 6 12:44:10 ovpn-client3[2804]: cf_per = 0
Jan 6 12:44:10 ovpn-client3[2804]: cf_initial_max = 100
Jan 6 12:44:10 ovpn-client3[2804]: cf_initial_per = 10
Jan 6 12:44:10 ovpn-client3[2804]: max_clients = 1024
Jan 6 12:44:10 ovpn-client3[2804]: max_routes_per_client = 256
Jan 6 12:44:10 ovpn-client3[2804]: auth_user_pass_verify_script = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: auth_user_pass_verify_script_via_file = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: auth_token_generate = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: auth_token_lifetime = 0
Jan 6 12:44:10 ovpn-client3[2804]: auth_token_secret_file = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: port_share_host = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: port_share_port = '[UNDEF]'
Jan 6 12:44:10 ovpn-client3[2804]: vlan_tagging = DISABLED
Jan 6 12:44:10 ovpn-client3[2804]: vlan_accept = all
Jan 6 12:44:10 ovpn-client3[2804]: vlan_pvid = 1
Jan 6 12:44:10 ovpn-client3[2804]: client = ENABLED
Jan 6 12:44:10 ovpn-client3[2804]: pull = ENABLED
Jan 6 12:44:10 ovpn-client3[2804]: auth_user_pass_file = 'auth'
Jan 6 12:44:10 ovpn-client3[2804]: OpenVPN 2.6.8 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Jan 6 12:44:10 ovpn-client3[2804]: library versions: OpenSSL 1.1.1w 11 Sep 2023, LZO 2.10
Jan 6 12:44:10 ovpn-client3[2805]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Jan 6 12:44:10 ovpn-client3[2805]: No valid translation found for TLS cipher 'TLS_CHACHA20_POLY1305_SHA256'
Jan 6 12:44:10 ovpn-client3[2805]: No valid translation found for TLS cipher 'TLS_AES_256_GCM_SHA384'
Jan 6 12:44:10 ovpn-client3[2805]: WARNING: INSECURE cipher (BF-CBC) with block size less than 128 bit (64 bit). This allows attacks like SWEET32. Mitigate by using a --cipher with a larger block size (e.g. AES-256-CBC). Support for these insecure ciphers will be removed in OpenVPN 2.7.
Jan 6 12:44:10 ovpn-client3[2805]: Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
Jan 6 12:44:10 ovpn-client3[2805]: Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
Jan 6 12:44:10 ovpn-client3[2805]: Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
Jan 6 12:44:10 ovpn-client3[2805]: Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
Jan 6 12:44:10 ovpn-client3[2805]: WARNING: if you use --mssfix and --fragment, you should use the "mtu" flag for both or none of of them.
Jan 6 12:44:10 ovpn-client3[2805]: Control Channel MTU parms [ mss_fix:0 max_frag:0 tun_mtu:1250 tun_max_mtu:0 headroom:126 payload:1600 tailroom:126 ET:0 ]
Jan 6 12:44:10 ovpn-client3[2805]: Data Channel MTU parms [ mss_fix:0 max_frag:0 tun_mtu:1500 tun_max_mtu:1600 headroom:136 payload:1768 tailroom:562 ET:0 ]
Jan 6 12:44:10 ovpn-client3[2805]: Fragmentation MTU parms [ mss_fix:1127 max_frag:1215 tun_mtu:1500 tun_max_mtu:1600 headroom:136 payload:1768 tailroom:562 ET:0 ]
Jan 6 12:44:10 ovpn-client3[2805]: TCP/UDP: Preserving recently used remote address: [AF_INET]162.245.206.242:1151
Jan 6 12:44:10 ovpn-client3[2805]: Socket Buffers: R=[524288->524288] S=[524288->524288]
Jan 6 12:44:10 ovpn-client3[2805]: UDPv4 link local: (not bound)
Jan 6 12:44:10 ovpn-client3[2805]: UDPv4 link remote: [AF_INET]162.245.206.242:1151
Jan 6 12:44:13 rc_service: watchdog 2513:notify_rc start_stubby
Jan 6 12:44:43 rc_service: watchdog 2513:notify_rc start_stubby
