Apr 27 21:18:47 openvpn[6437]: tls_timeout = 5
Apr 27 21:18:47 openvpn[6437]: renegotiate_bytes = -1
Apr 27 21:18:47 openvpn[6437]: renegotiate_packets = 0
Apr 27 21:18:47 openvpn[6437]: renegotiate_seconds = 3600
Apr 27 21:18:47 openvpn[6437]: handshake_window = 120
Apr 27 21:18:47 openvpn[6437]: transition_window = 3600
Apr 27 21:18:47 openvpn[6437]: single_session = DISABLED
Apr 27 21:18:47 openvpn[6437]: push_peer_info = DISABLED
Apr 27 21:18:47 openvpn[6437]: tls_exit = DISABLED
Apr 27 21:18:47 openvpn[6437]: tls_auth_file = 'static.key'
Apr 27 21:18:47 openvpn[6437]: tls_crypt_file = '[UNDEF]'
Apr 27 21:18:47 openvpn[6437]: server_network = 0.0.0.0
Apr 27 21:18:47 openvpn[6437]: server_netmask = 0.0.0.0
Apr 27 21:18:47 openvpn[6437]: server_network_ipv6 = ::
Apr 27 21:18:47 openvpn[6437]: server_netbits_ipv6 = 0
Apr 27 21:18:47 openvpn[6437]: server_bridge_ip = 0.0.0.0
Apr 27 21:18:47 openvpn[6437]: server_bridge_netmask = 0.0.0.0
Apr 27 21:18:47 openvpn[6437]: server_bridge_pool_start = 0.0.0.0
Apr 27 21:18:47 openvpn[6437]: server_bridge_pool_end = 0.0.0.0
Apr 27 21:18:47 openvpn[6437]: ifconfig_pool_defined = DISABLED
Apr 27 21:18:47 openvpn[6437]: ifconfig_pool_start = 0.0.0.0
Apr 27 21:18:47 openvpn[6437]: ifconfig_pool_end = 0.0.0.0
Apr 27 21:18:47 openvpn[6437]: ifconfig_pool_netmask = 0.0.0.0
Apr 27 21:18:47 openvpn[6437]: ifconfig_pool_persist_filename = '[UNDEF]'
Apr 27 21:18:47 openvpn[6437]: ifconfig_pool_persist_refresh_freq = 600
Apr 27 21:18:47 openvpn[6437]: ifconfig_ipv6_pool_defined = DISABLED
Apr 27 21:18:47 openvpn[6437]: ifconfig_ipv6_pool_base = ::
Apr 27 21:18:47 openvpn[6437]: ifconfig_ipv6_pool_netbits = 0
Apr 27 21:18:47 openvpn[6437]: n_bcast_buf = 256
Apr 27 21:18:47 openvpn[6437]: tcp_queue_limit = 64
Apr 27 21:18:47 openvpn[6437]: real_hash_size = 256
Apr 27 21:18:47 openvpn[6437]: virtual_hash_size = 256
Apr 27 21:18:47 openvpn[6437]: client_connect_script = '[UNDEF]'
Apr 27 21:18:47 openvpn[6437]: learn_address_script = '[UNDEF]'
Apr 27 21:18:47 openvpn[6437]: client_disconnect_script = '[UNDEF]'
Apr 27 21:18:47 openvpn[6437]: client_config_dir = '[UNDEF]'
Apr 27 21:18:47 openvpn[6437]: ccd_exclusive = DISABLED
Apr 27 21:18:47 openvpn[6437]: tmp_dir = '/tmp'
Apr 27 21:18:47 openvpn[6437]: push_ifconfig_defined = DISABLED
Apr 27 21:18:47 openvpn[6437]: push_ifconfig_local = 0.0.0.0
Apr 27 21:18:47 openvpn[6437]: push_ifconfig_remote_netmask = 0.0.0.0
Apr 27 21:18:47 openvpn[6437]: push_ifconfig_ipv6_defined = DISABLED
Apr 27 21:18:47 openvpn[6437]: push_ifconfig_ipv6_local = ::/0
Apr 27 21:18:47 openvpn[6437]: push_ifconfig_ipv6_remote = ::
Apr 27 21:18:47 openvpn[6437]: enable_c2c = DISABLED
Apr 27 21:18:47 openvpn[6437]: duplicate_cn = DISABLED
Apr 27 21:18:47 openvpn[6437]: cf_max = 0
Apr 27 21:18:47 openvpn[6437]: cf_per = 0
Apr 27 21:18:47 openvpn[6437]: max_clients = 1024
Apr 27 21:18:47 openvpn[6437]: max_routes_per_client = 256
Apr 27 21:18:47 openvpn[6437]: auth_user_pass_verify_script = '[UNDEF]'
Apr 27 21:18:47 openvpn[6437]: auth_user_pass_verify_script_via_file = DISABLED
Apr 27 21:18:47 openvpn[6437]: auth_token_generate = DISABLED
Apr 27 21:18:47 openvpn[6437]: auth_token_lifetime = 0
Apr 27 21:18:47 openvpn[6437]: port_share_host = '[UNDEF]'
Apr 27 21:18:47 openvpn[6437]: port_share_port = '[UNDEF]'
Apr 27 21:18:47 openvpn[6437]: client = ENABLED
Apr 27 21:18:47 openvpn[6437]: pull = ENABLED
Apr 27 21:18:47 openvpn[6437]: auth_user_pass_file = 'up'
Apr 27 21:18:47 openvpn[6437]: OpenVPN 2.4.0 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Feb 3 2017
Apr 27 21:18:47 openvpn[6437]: library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.08
Apr 27 21:18:47 openvpn[6438]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Apr 27 21:18:47 openvpn[6438]: Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Apr 27 21:18:47 openvpn[6438]: Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Apr 27 21:18:47 openvpn[6438]: LZO compression initializing
Apr 27 21:18:47 openvpn[6438]: Control Channel MTU parms [ L:1626 D:1140 EF:110 EB:0 ET:0 EL:3 ]
Apr 27 21:18:48 openvpn[6438]: Data Channel MTU parms [ L:1626 D:1300 EF:126 EB:407 ET:0 EL:3 ]
Apr 27 21:18:48 openvpn[6438]: Fragmentation MTU parms [ L:1626 D:1300 EF:125 EB:407 ET:1 EL:3 ]
Apr 27 21:18:48 openvpn[6438]: Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 1,cipher AES-128-CBC,auth SHA512,keysize 128,tls-auth,key-method 2,tls-client'
Apr 27 21:18:48 openvpn[6438]: Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 0,cipher AES-128-CBC,auth SHA512,keysize 128,tls-auth,key-method 2,tls-server'
Apr 27 21:18:48 openvpn[6438]: TCP/UDP: Preserving recently used remote address: [AF_INET]94.242.243.66:150
Apr 27 21:18:48 openvpn[6438]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Apr 27 21:18:48 openvpn[6438]: UDP link local: (not bound)
Apr 27 21:18:48 openvpn[6438]: UDP link remote: [AF_INET]94.242.243.66:150
Apr 27 21:18:48 openvpn[6438]: TLS: Initial packet from [AF_INET]94.242.243.66:150, sid=65502207 019446d1
Apr 27 21:18:48 openvpn[6438]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Apr 27 21:18:48 openvpn[6438]: VERIFY OK: depth=1, C=CH, ST=Zug, L=Zug, O=Perfect Privacy, CN=Perfect Privacy, emailAddress=admin@perfect-privacy.com
Apr 27 21:18:48 openvpn[6438]: VERIFY OK: nsCertType=SERVER
Apr 27 21:18:48 openvpn[6438]: VERIFY OK: depth=0, C=CH, ST=Zug, O=Perfect Privacy, CN=Server_steinsel.perfect-privacy.com, emailAddress=admin@perfect-privacy.com
Apr 27 21:20:48 openvpn[6438]: [Server_steinsel.perfect-privacy.com] Inactivity timeout (--ping-restart), restarting
Apr 27 21:20:48 openvpn[6438]: TCP/UDP: Closing socket
Apr 27 21:20:48 openvpn[6438]: SIGUSR1[soft,ping-restart] received, process restarting
Apr 27 21:20:48 openvpn[6438]: Restart pause, 5 second(s)
Apr 27 21:20:53 openvpn[6438]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Apr 27 21:20:53 openvpn[6438]: Re-using SSL/TLS context
Apr 27 21:20:53 openvpn[6438]: LZO compression initializing
Apr 27 21:20:53 openvpn[6438]: Control Channel MTU parms [ L:1626 D:1140 EF:110 EB:0 ET:0 EL:3 ]
Apr 27 21:20:53 openvpn[6438]: TCP/UDP: Preserving recently used remote address: [AF_INET]94.242.243.66:150
Apr 27 21:20:53 openvpn[6438]: Data Channel MTU parms [ L:1626 D:1300 EF:126 EB:407 ET:0 EL:3 ]
Apr 27 21:20:53 openvpn[6438]: Fragmentation MTU parms [ L:1626 D:1300 EF:125 EB:407 ET:1 EL:3 ]
Apr 27 21:20:53 openvpn[6438]: Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 1,cipher AES-128-CBC,auth SHA512,keysize 128,tls-auth,key-method 2,tls-client'
Apr 27 21:20:53 openvpn[6438]: Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 0,cipher AES-128-CBC,auth SHA512,keysize 128,tls-auth,key-method 2,tls-server'
Apr 27 21:20:53 openvpn[6438]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Apr 27 21:20:53 openvpn[6438]: UDP link local: (not bound)
Apr 27 21:20:53 openvpn[6438]: UDP link remote: [AF_INET]94.242.243.66:150
Apr 27 21:20:53 openvpn[6438]: TLS: Initial packet from [AF_INET]94.242.243.66:150, sid=e03d3365 591153e3
Apr 27 21:20:54 openvpn[6438]: VERIFY OK: depth=1, C=CH, ST=Zug, L=Zug, O=Perfect Privacy, CN=Perfect Privacy, emailAddress=admin@perfect-privacy.com
Apr 27 21:20:54 openvpn[6438]: VERIFY OK: nsCertType=SERVER
Apr 27 21:20:54 openvpn[6438]: VERIFY OK: depth=0, C=CH, ST=Zug, O=Perfect Privacy, CN=Server_steinsel.perfect-privacy.com, emailAddress=admin@perfect-privacy.com
Apr 27 21:22:53 openvpn[6438]: TLS Error: TLS key negotiation failed to occur within 120 seconds (check your network connectivity)
Apr 27 21:22:53 openvpn[6438]: TLS Error: TLS handshake failed
Apr 27 21:22:53 openvpn[6438]: TCP/UDP: Closing socket
Apr 27 21:22:53 openvpn[6438]: SIGUSR1[soft,tls-error] received, process restarting
Apr 27 21:22:53 openvpn[6438]: Restart pause, 5 second(s)
