I've been using openvpn on Linux for months with no problem, but suddenly no matter which server I connect to, it ends up connected to Frankfurt or Amsterdam.
I followed the tutorial here: https://www.perfect-privacy.com/howto/openvpn-linux-terminal/ and implemented the fix here: https://board.perfect-privacy.com/threads/openvpn-on-linux-terminal.1510/
When I try to connect to Miami using "sudo openvpn /etc/openvpn/Miami.ovpn" I get the output:
If I run "wget -q -O - https://checkip.perfect-privacy.com/csv" I get the output:
I do see some issues with ipv6 here, but I still don't understand why this would result in a successful connection to a server in Amsterdam?
Wed Jun 27 18:02:43 2018 us=821580 OpenVPN 2.4.4 x86_64-redhat-linux-gnu [Fedora EPEL patched] [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Nov 1 2017
Wed Jun 27 18:02:43 2018 us=821592 library versions: OpenSSL 1.0.2k-fips 26 Jan 2017, LZO 2.08
Wed Jun 27 18:02:43 2018 us=822446 WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Wed Jun 27 18:02:43 2018 us=822460 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Wed Jun 27 18:02:43 2018 us=822827 Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Wed Jun 27 18:02:43 2018 us=822846 Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Wed Jun 27 18:02:43 2018 us=822858 LZO compression initializing
Wed Jun 27 18:02:43 2018 us=822921 Control Channel MTU parms [ L:1626 D:1140 EF:110 EB:0 ET:0 EL:3 ]
Wed Jun 27 18:02:43 2018 us=937290 Data Channel MTU parms [ L:1626 D:1300 EF:126 EB:407 ET:0 EL:3 ]
Wed Jun 27 18:02:43 2018 us=937355 Fragmentation MTU parms [ L:1626 D:1300 EF:125 EB:407 ET:1 EL:3 ]
Wed Jun 27 18:02:43 2018 us=937432 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 1,cipher AES-256-CBC,auth SHA512,keysize 256,tls-auth,key-method 2,tls-client'
Wed Jun 27 18:02:43 2018 us=937485 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 0,cipher AES-256-CBC,auth SHA512,keysize 256,tls-auth,key-method 2,tls-server'
Wed Jun 27 18:02:43 2018 us=937534 TCP/UDP: Preserving recently used remote address: [AF_INET]38.132.***.***:1149
Wed Jun 27 18:02:43 2018 us=937594 Socket Buffers: R=[212992->212992] S=[212992->212992]
Wed Jun 27 18:02:43 2018 us=937634 UDP link local: (not bound)
Wed Jun 27 18:02:43 2018 us=937680 UDP link remote: [AF_INET]38.132.***.***:1149
Wed Jun 27 18:02:43 2018 us=965239 TLS: Initial packet from [AF_INET]38.132.***.***:1149, sid=5c239ef5 718378e8
Wed Jun 27 18:02:43 2018 us=965472 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Wed Jun 27 18:02:44 2018 us=52399 VERIFY OK: depth=1, C=CH, ST=Zug, L=Zug, O=Perfect Privacy, CN=Perfect Privacy, emailAddress=admin@perfect-privacy.com
Wed Jun 27 18:02:44 2018 us=52799 VERIFY OK: nsCertType=SERVER
Wed Jun 27 18:02:44 2018 us=52857 VERIFY OK: depth=0, C=CH, ST=Zug, O=Perfect Privacy, CN=Server_miami.perfect-privacy.com, emailAddress=admin@perfect-privacy.com
Wed Jun 27 18:02:44 2018 us=284071 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
Wed Jun 27 18:02:44 2018 us=284257 [Server_miami.perfect-privacy.com] Peer Connection Initiated with [AF_INET]38.132.***.***:1149
Wed Jun 27 18:02:45 2018 us=528708 SENT CONTROL [Server_miami.perfect-privacy.com]: 'PUSH_REQUEST' (status=1)
Wed Jun 27 18:02:45 2018 us=556080 PUSH: Received control message: 'PUSH_REPLY,topology subnet,redirect-gateway def1,sndbuf 131072,rcvbuf 131072,comp-lzo adaptive,route-gateway 10.3.***.***,redirect-gateway ipv6,route-ipv6 2000::/3,ping 10,ping-restart 60,dhcp-option DNS 38.132.***.***,dhcp-option DNS 78.129.***.***,ifconfig-ipv6 fdbf:****:****:0:56::1240/112 fdbf:****:****:0:56::1,ifconfig 10.3.***.*** 255.255.255.0,peer-id 0'
Wed Jun 27 18:02:45 2018 us=556248 OPTIONS IMPORT: timers and/or timeouts modified
Wed Jun 27 18:02:45 2018 us=556297 OPTIONS IMPORT: compression parms modified
Wed Jun 27 18:02:45 2018 us=556363 LZO compression initializing
Wed Jun 27 18:02:45 2018 us=556420 OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
Wed Jun 27 18:02:45 2018 us=556468 Socket Buffers: R=[212***->262***] S=[212***->262***]
Wed Jun 27 18:02:45 2018 us=556511 OPTIONS IMPORT: --ifconfig/up options modified
Wed Jun 27 18:02:45 2018 us=556550 OPTIONS IMPORT: route options modified
Wed Jun 27 18:02:45 2018 us=556590 OPTIONS IMPORT: route-related options modified
Wed Jun 27 18:02:45 2018 us=556629 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Wed Jun 27 18:02:45 2018 us=556662 OPTIONS IMPORT: peer-id set
Wed Jun 27 18:02:45 2018 us=556686 OPTIONS IMPORT: adjusting link_mtu to 1629
Wed Jun 27 18:02:45 2018 us=556717 Data Channel MTU parms [ L:1609 D:1300 EF:109 EB:407 ET:0 EL:3 ]
Wed Jun 27 18:02:45 2018 us=556810 Outgoing Data Channel: Cipher 'AES-256-CBC' initialized with 256 bit key
Wed Jun 27 18:02:45 2018 us=556843 Outgoing Data Channel: Using 512 bit message hash 'SHA512' for HMAC authentication
Wed Jun 27 18:02:45 2018 us=556872 Incoming Data Channel: Cipher 'AES-256-CBC' initialized with 256 bit key
Wed Jun 27 18:02:45 2018 us=556900 Incoming Data Channel: Using 512 bit message hash 'SHA512' for HMAC authentication
Wed Jun 27 18:02:45 2018 us=557066 ROUTE_GATEWAY 10.0.0.1/255.255.255.0 IFACE=eth0 HWADDR=0e:9c:d1:2a:7c:d2
Wed Jun 27 18:02:45 2018 us=557109 GDG6: remote_host_ipv6=n/a
Wed Jun 27 18:02:45 2018 us=557159 GDG6: NLMSG_ERROR: error No route to host
Wed Jun 27 18:02:45 2018 us=557205 ROUTE6: default_gateway=UNDEF
Wed Jun 27 18:02:45 2018 us=563998 TUN/TAP device tun0 opened
Wed Jun 27 18:02:45 2018 us=564024 TUN/TAP TX queue length set to 100
Wed Jun 27 18:02:45 2018 us=564036 do_ifconfig, tt->did_ifconfig_ipv6_setup=1
Wed Jun 27 18:02:45 2018 us=564051 /sbin/ip link set dev tun0 up mtu 1500
Wed Jun 27 18:02:45 2018 us=565686 /sbin/ip addr add dev tun0 10.3.***.***/24 broadcast 10.3.***.***
Wed Jun 27 18:02:45 2018 us=566474 /sbin/ip -6 addr add fdbf:****:****:0:56::1240/112 dev tun0
Wed Jun 27 18:02:45 2018 us=568210 /etc/openvpn/client.up tun0 1500 1609 10.3.***.*** 255.255.255.0 init
Wed Jun 27 18:02:47 2018 us=825396 /sbin/ip route add 38.132.***.***/32 via 10.0.0.1
Wed Jun 27 18:02:47 2018 us=826342 /sbin/ip route add 0.0.0.0/1 via 10.3.***.***
Wed Jun 27 18:02:47 2018 us=827075 /sbin/ip route add 128.0.0.0/1 via 10.3.***.***
Wed Jun 27 18:02:47 2018 us=827722 add_route_ipv6(2000::/3 -> fdbf:****:****:0:56::1 metric -1) dev tun0
Wed Jun 27 18:02:47 2018 us=827746 /sbin/ip -6 route add 2000::/3 dev tun0
Wed Jun 27 18:02:47 2018 us=828463 add_route_ipv6:/3 -> fdbf:****:****:0:56::1 metric -1) dev tun0
Wed Jun 27 18:02:47 2018 us=828497 /sbin/ip -6 route add ::/3 dev tun0
Wed Jun 27 18:02:47 2018 us=829082 add_route_ipv6(2000::/4 -> fdbf:****:****:0:56::1 metric -1) dev tun0
Wed Jun 27 18:02:47 2018 us=829101 /sbin/ip -6 route add 2000::/4 dev tun0
Wed Jun 27 18:02:47 2018 us=829745 add_route_ipv6(3000::/4 -> fdbf:****:****:0:56::1 metric -1) dev tun0
Wed Jun 27 18:02:47 2018 us=829778 /sbin/ip -6 route add 3000::/4 dev tun0
Wed Jun 27 18:02:47 2018 us=830442 add_route_ipv6(fc00::/7 -> fdbf:****:****:0:56::1 metric -1) dev tun0
Wed Jun 27 18:02:47 2018 us=830463 /sbin/ip -6 route add fc00::/7 dev tun0
Wed Jun 27 18:02:47 2018 us=831124 Initialization Sequence Completed
IP,DNS,VPN,TOR,COUNTRY,CITY
95.211.**.***,amsterdam2.perfect-privacy.com,true,false,Netherlands,Amsterdam
