Answered: VPN, Router and Firewall Config for Transmission
AndySw
Hi, I'm having trouble getting Transmission ( https://transmissionbt.com/ ) to work through the VPN.
I'm using the VPN Manager software and have it configured port forwarding using 1-to-1 port forwarding and 'add forwarding to custom port'
I've also tried setting up port forwarding on my router, mirroring the config in VPN manager.
Transmission allows you to configure the port you want to use, and to test it. With the VPN disabled, the test passes but with the VPN enabled, with various attempts at setting up the port forwarding in the VPN Manager and also in the router, the test fails.
Please would someone be able to point me in the right direction? Thanks.
Andy.
