Setting up ExpressVPN as network interface in qBittorrent v5.1.2
Captainguy
Hello, I am looking for a way to connect expressvpn to qbittorrent. For most vpns an option should just pop up, but for some reason not for express vpn. I search for some possible solutions to this and found on an old reddit thread that you can determine which interface expressvpn is using by searching up ipconfig in your command prompt, once with and once without to observe changes, and the interface that has a different ip with it on and off will be your option. However, my problem is that I am not seeing any differences. Has anyone encountered this specific problem?
WITH VPN ON WITH VPN OFF
Und außerdem ist hier nicht das englische Forum, das ist dort:
