Beantwortet: Router mit Tomato sw VPN Probleme
chris2011
Hallo
Ich versuche PP über meinen Router R7000 mit Tomato sw per Openvpn zum laufen zu bringen, aber irgendwie klappt es nicht, kann mir jemand einen Tipp geben danke!!!
Meine Einstellungen
habe ich übernommen aus diesem Thread
https://board.perfect-privacy.com/fo...-asus-rt-ac66u
Dec 25 16:04:24 unknown kern.info kernel: tun: Universal TUN/TAP device driver, 1.6 Dec 25 16:04:24 unknown kern.info kernel: tun: (C) 1999-2004 Max Krasnyansky Dec 25 16:04:24 unknown daemon.notice openvpn[2033]: OpenVPN 2.3.4 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Nov 1 2014 Dec 25 16:04:24 unknown daemon.notice openvpn[2033]: library versions: OpenSSL 1.0.1i 6 Aug 2014, LZO 2.06 Dec 25 16:04:24 unknown daemon.warn openvpn[2033]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Dec 25 16:04:24 unknown daemon.warn openvpn[2033]: Deprecated TLS cipher name 'DHE-RSA-AES256-GCM-SHA384', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-GCM-SHA384' Dec 25 16:04:24 unknown daemon.warn openvpn[2033]: Deprecated TLS cipher name 'DHE-RSA-AES256-SHA256', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-CBC-SHA256' Dec 25 16:04:24 unknown daemon.warn openvpn[2033]: Deprecated TLS cipher name 'DHE-RSA-AES128-GCM-SHA256', please use IANA name 'TLS-DHE-RSA-WITH-AES-128-GCM-SHA256' Dec 25 16:04:24 unknown daemon.warn openvpn[2033]: Deprecated TLS cipher name 'DHE-RSA-AES128-SHA256', please use IANA name 'TLS-DHE-RSA-WITH-AES-128-CBC-SHA256' Dec 25 16:04:24 unknown daemon.warn openvpn[2033]: Deprecated TLS cipher name 'DHE-RSA-CAMELLIA256-SHA', please use IANA name 'TLS-DHE-RSA-WITH-CAMELLIA-256-CBC-SHA' Dec 25 16:04:24 unknown daemon.warn openvpn[2033]: Deprecated TLS cipher name 'DHE-RSA-AES256-SHA', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-CBC-SHA' Dec 25 16:04:24 unknown daemon.warn openvpn[2033]: Deprecated TLS cipher name 'DHE-RSA-CAMELLIA128-SHA', please use IANA name 'TLS-DHE-RSA-WITH-CAMELLIA-128-CBC-SHA' Dec 25 16:04:24 unknown daemon.warn openvpn[2033]: Deprecated TLS cipher name 'DHE-RSA-AES128-SHA', please use IANA name 'TLS-DHE-RSA-WITH-AES-128-CBC-SHA' Dec 25 16:04:24 unknown daemon.warn openvpn[2033]: Deprecated TLS cipher name 'CAMELLIA256-SHA', please use IANA name 'TLS-RSA-WITH-CAMELLIA-256-CBC-SHA' Dec 25 16:04:24 unknown daemon.warn openvpn[2033]: Deprecated TLS cipher name 'AES256-SHA', please use IANA name 'TLS-RSA-WITH-AES-256-CBC-SHA' Dec 25 16:04:24 unknown daemon.warn openvpn[2033]: Deprecated TLS cipher name 'CAMELLIA128-SHA', please use IANA name 'TLS-RSA-WITH-CAMELLIA-128-CBC-SHA' Dec 25 16:04:24 unknown daemon.warn openvpn[2033]: Deprecated TLS cipher name 'AES128-SHA', please use IANA name 'TLS-RSA-WITH-AES-128-CBC-SHA' Dec 25 16:04:24 unknown daemon.notice openvpn[2033]: Control Channel Authentication: using 'static.key' as a OpenVPN static key file Dec 25 16:04:24 unknown daemon.notice openvpn[2033]: Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication Dec 25 16:04:24 unknown daemon.notice openvpn[2033]: Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication Dec 25 16:04:24 unknown daemon.notice openvpn[2033]: LZO compression initialized Dec 25 16:04:24 unknown daemon.notice openvpn[2033]: Control Channel MTU parms [ L:1606 D:210 EF:110 EB:0 ET:0 EL:0 ] Dec 25 16:04:24 unknown daemon.notice openvpn[2033]: Socket Buffers: R=[120832->131072] S=[120832->131072] Dec 25 16:04:24 unknown daemon.notice openvpn[2033]: Data Channel MTU parms [ L:1606 D:1300 EF:106 EB:135 ET:0 EL:0 AF:3/1 ] Dec 25 16:04:24 unknown daemon.notice openvpn[2033]: Fragmentation MTU parms [ L:1606 D:1300 EF:105 EB:135 ET:1 EL:0 AF:3/1 ] Dec 25 16:04:24 unknown daemon.notice openvpn[2038]: UDPv4 link local: [undef] Dec 25 16:04:24 unknown daemon.notice openvpn[2038]: UDPv4 link remote: [AF_INET]37.48.74.75:1149 Dec 25 16:04:24 unknown daemon.notice openvpn[2038]: TLS: Initial packet from [AF_INET]37.48.74.75:1149, sid=78b5ff62 aa94ed74 Dec 25 16:04:24 unknown daemon.warn openvpn[2038]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this Dec 25 16:04:25 unknown daemon.notice openvpn[2038]: VERIFY OK: depth=1, C=NZ, ST=Wellington, L=Johnsonville, O=perfect-privacy, CN=perfect-privacy, emailAddress=admin@perfect-privacy.com Dec 25 16:04:25 unknown daemon.notice openvpn[2038]: VERIFY OK: nsCertType=SERVER Dec 25 16:04:25 unknown daemon.notice openvpn[2038]: VERIFY OK: depth=0, C=NZ, ST=Wellington, O=perfect-privacy, CN=server, emailAddress=admin@perfect-privacy.com Dec 25 16:04:28 unknown daemon.notice openvpn[2038]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Dec 25 16:04:28 unknown daemon.notice openvpn[2038]: Data Channel Encrypt: Using 512 bit message hash 'SHA512' for HMAC authentication Dec 25 16:04:28 unknown daemon.notice openvpn[2038]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Dec 25 16:04:28 unknown daemon.notice openvpn[2038]: Data Channel Decrypt: Using 512 bit message hash 'SHA512' for HMAC authentication Dec 25 16:04:28 unknown daemon.notice openvpn[2038]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA Dec 25 16:04:28 unknown daemon.notice openvpn[2038]: [server] Peer Connection Initiated with [AF_INET]37.48.74.75:1149 Dec 25 16:04:29 unknown daemon.err openvpn[2038]: event_wait : Interrupted system call (code=4) Dec 25 16:04:29 unknown daemon.notice openvpn[2038]: OpenVPN STATISTICS Dec 25 16:04:29 unknown daemon.notice openvpn[2038]: Updated,Thu Dec 25 16:04:29 2014 Dec 25 16:04:29 unknown daemon.notice openvpn[2038]: TUN/TAP read bytes,0 Dec 25 16:04:29 unknown daemon.notice openvpn[2038]: TUN/TAP write bytes,0 Dec 25 16:04:29 unknown daemon.notice openvpn[2038]: TCP/UDP read bytes,15189 Dec 25 16:04:29 unknown daemon.notice openvpn[2038]: TCP/UDP write bytes,14664 Dec 25 16:04:29 unknown daemon.notice openvpn[2038]: Auth read bytes,0 Dec 25 16:04:29 unknown daemon.notice openvpn[2038]: pre-compress bytes,0 Dec 25 16:04:29 unknown daemon.notice openvpn[2038]: post-compress bytes,0 Dec 25 16:04:29 unknown daemon.notice openvpn[2038]: pre-decompress bytes,0 Dec 25 16:04:30 unknown daemon.notice openvpn[2038]: SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Dec 25 16:04:30 unknown daemon.notice openvpn[2038]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 46.4.77.77,dhcp-option DNS 185.19.87.36,route-gateway 10.15.11.1,topology subnet,ping 10,ping-restart 120,ifconfig 10.15.11.9 255.255.255.128' Dec 25 16:04:30 unknown daemon.notice openvpn[2038]: OPTIONS IMPORT: timers and/or timeouts modified Dec 25 16:04:30 unknown daemon.notice openvpn[2038]: OPTIONS IMPORT: --ifconfig/up options modified Dec 25 16:04:30 unknown daemon.notice openvpn[2038]: OPTIONS IMPORT: route options modified Dec 25 16:04:30 unknown daemon.notice openvpn[2038]: OPTIONS IMPORT: route-related options modified Dec 25 16:04:30 unknown daemon.notice openvpn[2038]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified Dec 25 16:04:30 unknown daemon.notice openvpn[2038]: TUN/TAP device tun11 opened Dec 25 16:04:30 unknown daemon.notice openvpn[2038]: TUN/TAP TX queue length set to 100 Dec 25 16:04:30 unknown daemon.notice openvpn[2038]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 Dec 25 16:04:30 unknown daemon.notice openvpn[2038]: /sbin//ifconfig tun11 10.15.11.9 netmask 255.255.255.128 mtu 1500 broadcast 10.15.11.127 Dec 25 16:04:30 unknown daemon.notice openvpn[2038]: updown.sh tun11 1500 1606 10.15.11.9 255.255.255.128 init Dec 25 16:04:30 unknown daemon.info dnsmasq[2016]: exiting on receipt of SIGTERM Dec 25 16:04:30 unknown user.debug preinit[1]: 182: pptp peerdns disabled Dec 25 16:04:30 unknown daemon.info dnsmasq[2087]: started, version 2.71 cachesize 1500 Dec 25 16:04:30 unknown daemon.info dnsmasq[2087]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset Tomato-helper auth DNSSEC Dec 25 16:04:30 unknown daemon.info dnsmasq[2087]: asynchronous logging enabled, queue limit is 5 messages Dec 25 16:04:30 unknown daemon.info dnsmasq-dhcp[2087]: DHCP, IP range 192.168.50.100 -- 192.168.50.149, lease time 1d Dec 25 16:04:30 unknown daemon.info dnsmasq[2087]: reading /etc/resolv.dnsmasq Dec 25 16:04:30 unknown daemon.info dnsmasq[2087]: using nameserver 46.4.77.77#53 Dec 25 16:04:30 unknown daemon.info dnsmasq[2087]: using nameserver 185.19.87.36#53 Dec 25 16:04:30 unknown daemon.info dnsmasq[2087]: using nameserver 213.33.98.136#53 Dec 25 16:04:30 unknown daemon.info dnsmasq[2087]: read /etc/hosts - 2 addresses Dec 25 16:04:30 unknown daemon.info dnsmasq[2087]: read /etc/dnsmasq/hosts/hosts - 3 addresses Dec 25 16:04:30 unknown daemon.info dnsmasq-dhcp[2087]: read /etc/dnsmasq/dhcp/dhcp-hosts Dec 25 16:04:32 unknown daemon.notice openvpn[2038]: /sbin//route add -net 37.48.74.75 netmask 255.255.255.255 gw 88.117.63.254 Dec 25 16:04:32 unknown daemon.warn openvpn[2038]: ERROR: Linux route add command failed: external program exited with error status: 1 Dec 25 16:04:32 unknown daemon.notice openvpn[2038]: /sbin//route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.15.11.1 Dec 25 16:04:32 unknown daemon.notice openvpn[2038]: /sbin//route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.15.11.1 Dec 25 16:04:32 unknown daemon.notice openvpn[2038]: Initialization Sequence Completed
