OVPN Tunnel bricht zusammen
efgheni
Feb 2 09:01:52 ovpn-client1[2459]: [Server_calais.perfect-privacy.com] Inactivity timeout (--ping-restart), restarting
Feb 2 09:02:57 ovpn-client1[2459]: TCP/UDP: Closing socket
Feb 2 09:02:57 ovpn-client1[2459]: SIGUSR1[soft,ping-restart] received, process restarting
Feb 2 09:02:57 ovpn-client1[2459]: Restart pause, 5 second(s)
Feb 2 09:03:02 ovpn-client1[2459]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Feb 2 09:03:02 ovpn-client1[2459]: Re-using SSL/TLS context
Feb 2 09:03:02 ovpn-client1[2459]: Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Feb 2 09:03:02 ovpn-client1[2459]: Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Feb 2 09:03:02 ovpn-client1[2459]: LZO compression initializing
Feb 2 09:03:02 ovpn-client1[2459]: Control Channel MTU parms [ L:1626 D:1140 EF:110 EB:0 ET:0 EL:3 ]
Feb 2 09:03:02 ovpn-client1[2459]: TCP/UDP: Preserving recently used remote address: [AF_INET]149.202.77.77:1151
Feb 2 09:03:02 ovpn-client1[2459]: Data Channel MTU parms [ L:1626 D:1300 EF:126 EB:407 ET:0 EL:3 ]
Feb 2 09:03:02 ovpn-client1[2459]: Fragmentation MTU parms [ L:1626 D:1300 EF:125 EB:407 ET:1 EL:3 ]
Feb 2 09:03:02 ovpn-client1[2459]: Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 1,cipher AES-128-CBC,auth SHA512,keysize 128,tls-auth,key-method 2,tls-client'
Feb 2 09:03:02 ovpn-client1[2459]: Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 0,cipher AES-128-CBC,auth SHA512,keysize 128,tls-auth,key-method 2,tls-server'
Feb 2 09:03:02 ovpn-client1[2459]: Socket Buffers: R=[524288->262144] S=[524288->262144]
Feb 2 09:03:02 ovpn-client1[2459]: UDP link local: (not bound)
Feb 2 09:03:02 ovpn-client1[2459]: UDP link remote: [AF_INET]149.202.77.77:1151
Feb 2 09:04:02 ovpn-client1[2459]: [UNDEF] Inactivity timeout (--ping-restart), restarting
Feb 2 09:04:02 ovpn-client1[2459]: TCP/UDP: Closing socket
Feb 2 09:04:02 ovpn-client1[2459]: SIGUSR1[soft,ping-restart] received, process restarting
Feb 2 09:04:02 ovpn-client1[2459]: Restart pause, 5 second(s)
Feb 2 09:04:07 ovpn-client1[2459]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Feb 2 09:04:07 ovpn-client1[2459]: Re-using SSL/TLS context
Feb 2 09:04:07 ovpn-client1[2459]: Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Feb 2 09:04:07 ovpn-client1[2459]: Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Feb 2 09:04:07 ovpn-client1[2459]: LZO compression initializing
Feb 2 09:04:07 ovpn-client1[2459]: Control Channel MTU parms [ L:1626 D:1140 EF:110 EB:0 ET:0 EL:3 ]
Feb 2 09:04:07 ovpn-client1[2459]: TCP/UDP: Preserving recently used remote address: [AF_INET]149.202.77.77:1151
Feb 2 09:04:07 ovpn-client1[2459]: Data Channel MTU parms [ L:1626 D:1300 EF:126 EB:407 ET:0 EL:3 ]
Feb 2 09:04:07 ovpn-client1[2459]: Fragmentation MTU parms [ L:1626 D:1300 EF:125 EB:407 ET:1 EL:3 ]
Feb 2 09:04:07 ovpn-client1[2459]: Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 1,cipher AES-128-CBC,auth SHA512,keysize 128,tls-auth,key-method 2,tls-client'
Feb 2 09:04:07 ovpn-client1[2459]: Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 0,cipher AES-128-CBC,auth SHA512,keysize 128,tls-auth,key-method 2,tls-server'
Feb 2 09:04:07 ovpn-client1[2459]: Socket Buffers: R=[524288->262144] S=[524288->262144]
Feb 2 09:04:07 ovpn-client1[2459]: UDP link local: (not bound)
Feb 2 09:04:07 ovpn-client1[2459]: UDP link remote: [AF_INET]149.202.77.77:1151
Feb 2 09:04:27 wlceventd: wlceventd_proc_event(486): eth7: Disassoc 32:84:20:48:EC:3C, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Feb 2 09:04:27 hostapd: eth7: STA 32:84:20:48:ec:3c IEEE 802.11: disassociated
Feb 2 09:04:32 wlceventd: wlceventd_proc_event(505): eth7: Auth 32:84:20:48:EC:3C, status: Successful (0)
Feb 2 09:04:32 wlceventd: wlceventd_proc_event(534): eth7: Assoc 32:84:20:48:EC:3C, status: Successful (0)
Feb 2 09:04:32 hostapd: eth7: STA 32:84:20:48:ec:3c IEEE 802.11: associated
Feb 2 09:04:32 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Feb 2 09:04:32 hostapd: eth7: STA 32:84:20:48:ec:3c RADIUS: starting accounting session 86A806EEEECCD38F
Feb 2 09:04:32 hostapd: eth7: STA 32:84:20:48:ec:3c WPA: pairwise key handshake completed (RSN)
Feb 2 09:05:07 ovpn-client1[2459]: [UNDEF] Inactivity timeout (--ping-restart), restarting
Feb 2 09:05:07 ovpn-client1[2459]: TCP/UDP: Closing socket
Feb 2 09:05:07 ovpn-client1[2459]: SIGUSR1[soft,ping-restart] received, process restarting
Feb 2 09:05:07 ovpn-client1[2459]: Restart pause, 5 second(s)
Feb 2 09:05:12 ovpn-client1[2459]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Feb 2 09:05:12 ovpn-client1[2459]: Re-using SSL/TLS context
Feb 2 09:05:12 ovpn-client1[2459]: Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Feb 2 09:05:12 ovpn-client1[2459]: Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Feb 2 09:05:12 ovpn-client1[2459]: LZO compression initializing
Feb 2 09:05:12 ovpn-client1[2459]: Control Channel MTU parms [ L:1626 D:1140 EF:110 EB:0 ET:0 EL:3 ]
Feb 2 09:05:12 ovpn-client1[2459]: TCP/UDP: Preserving recently used remote address: [AF_INET]149.202.77.77:1151
Feb 2 09:05:12 ovpn-client1[2459]: Data Channel MTU parms [ L:1626 D:1300 EF:126 EB:407 ET:0 EL:3 ]
Feb 2 09:05:12 ovpn-client1[2459]: Fragmentation MTU parms [ L:1626 D:1300 EF:125 EB:407 ET:1 EL:3 ]
Feb 2 09:05:12 ovpn-client1[2459]: Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 1,cipher AES-128-CBC,auth SHA512,keysize 128,tls-auth,key-method 2,tls-client'
Feb 2 09:05:12 ovpn-client1[2459]: Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 0,cipher AES-128-CBC,auth SHA512,keysize 128,tls-auth,key-method 2,tls-server'
Feb 2 09:05:12 ovpn-client1[2459]: Socket Buffers: R=[524288->262144] S=[524288->262144]
Feb 2 09:05:12 ovpn-client1[2459]: UDP link local: (not bound)
Feb 2 09:05:12 ovpn-client1[2459]: UDP link remote: [AF_INET]149.202.77.77:1151
Feb 2 09:06:12 ovpn-client1[2459]: [UNDEF] Inactivity timeout (--ping-restart), restarting
Feb 2 09:06:12 ovpn-client1[2459]: TCP/UDP: Closing socket
Feb 2 09:06:12 ovpn-client1[2459]: SIGUSR1[soft,ping-restart] received, process restarting
Feb 2 09:06:12 ovpn-client1[2459]: Restart pause, 5 second(s)
Feb 2 09:06:17 ovpn-client1[2459]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Feb 2 09:06:17 ovpn-client1[2459]: Re-using SSL/TLS context
Feb 2 09:06:17 ovpn-client1[2459]: Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Feb 2 09:06:17 ovpn-client1[2459]: Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Feb 2 09:06:17 ovpn-client1[2459]: LZO compression initializing
Feb 2 09:06:17 ovpn-client1[2459]: Control Channel MTU parms [ L:1626 D:1140 EF:110 EB:0 ET:0 EL:3 ]
Feb 2 09:06:17 ovpn-client1[2459]: TCP/UDP: Preserving recently used remote address: [AF_INET]149.202.77.77:1151
Feb 2 09:06:17 ovpn-client1[2459]: Data Channel MTU parms [ L:1626 D:1300 EF:126 EB:407 ET:0 EL:3 ]
Feb 2 09:06:17 ovpn-client1[2459]: Fragmentation MTU parms [ L:1626 D:1300 EF:125 EB:407 ET:1 EL:3 ]
Feb 2 09:06:17 ovpn-client1[2459]: Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 1,cipher AES-128-CBC,auth SHA512,keysize 128,tls-auth,key-method 2,tls-client'
Feb 2 09:06:17 ovpn-client1[2459]: Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 0,cipher AES-128-CBC,auth SHA512,keysize 128,tls-auth,key-method 2,tls-server'
Feb 2 09:06:17 ovpn-client1[2459]: Socket Buffers: R=[524288->262144] S=[524288->262144]
Feb 2 09:06:17 ovpn-client1[2459]: UDP link local: (not bound)
Feb 2 09:06:17 ovpn-client1[2459]: UDP link remote: [AF_INET]149.202.77.77:1151
hab Ovpn 2 oder 3 tage am laufen und auf einmal bricht der Tunnel einfach so zusammen und baut sich nicht mehr auf. Kann jemand sehen warum das so is?
