Solved: OpenVPN works but IPSEC doesn't work
aidenricky
i cant connect to servers with IPSEC option selected. however it works when i select OpenVPN. But i want to use IPSEC option.. what should i do? can someone help me?
aidenricky
i completely disabled firewall but still i cant connect to servers.
Error code 809: DotRas.RasDial Exception: the network connection between your computer and VPN server couldnt be established
bigplayer
You have to open the ports in the Firewall of your Router. They are really often blocked by ISP default settings. For ikev2 you have to open Port 500 UDP and Port 4500 UDP. https://blogs.technet.microsoft.com...s-to-unblock-for-vpn-traffic-to-pass-through/
Just to disable Windows Firewall isn't enough iff its blocked by your router.
If you don't know how to do, google your router model and firewall settings for it ;)
