Ich habe heute den Rechner (Windows 7 pro) eingeschaltet und bekam keine Verbindung mehr per OpenVPN. Über IPSEC geht es.
Ich habe die neueste Manager Version: 1.10.38.0 und Konfiguration: 1633611767.
Alles deinstallieren und neu installieren bringt nichts.
20.10.2021 11:21:39 Debug Debug: config connect called
20.10.2021 11:21:39 Log DisconnectReason set to NoDisconnect in connect_thread
20.10.2021 11:21:39 Log Debug: connect_thread started
20.10.2021 11:21:40 Log State Change Event - Initializing
20.10.2021 11:21:40 Log Waiting for OpenVPN.exe to get ready
20.10.2021 11:21:40 Log OpenVPN.exe ready
20.10.2021 11:21:40 Log Checking firewall and DNS leak protection settings
20.10.2021 11:21:43 Log Waiting for network to get ready
20.10.2021 11:21:43 Management Launching obfuscation plugin 'obfsproxy'
20.10.2021 11:21:44 Debug Proxy:127.0.0.1 VpnServer:217.114.218.21 RemoteIp:217.114.218.21
20.10.2021 11:21:44 Debug Debug: Serviceconnection connect called
20.10.2021 11:21:45 Management Connecting to management interface 127.0.0.1:11300
20.10.2021 11:21:47 Management Connecting to management interface 127.0.0.1:11300
20.10.2021 11:21:49 Management Connecting to management interface 127.0.0.1:11300
20.10.2021 11:21:51 Management Connecting to management interface 127.0.0.1:11300
20.10.2021 11:21:53 Management Connecting to management interface 127.0.0.1:11300
20.10.2021 11:21:55 Management Connecting to management interface 127.0.0.1:11300
20.10.2021 11:21:57 Management Connecting to management interface 127.0.0.1:11300
20.10.2021 11:21:58 Error Could not establish connection to management interface, abording
20.10.2021 11:21:58 Error error set in connect logic
20.10.2021 11:21:58 Log State Change Event - Error
20.10.2021 11:21:58 Log error handler is setting disconnect reasond to error!
20.10.2021 11:21:58 Debug Debug: Serviceconnection Disconnect called
20.10.2021 11:21:58 Debug ServiceConnection Disconnect statechange to VPNConnectionState.Stopped, was Error
20.10.2021 11:21:58 Log State Change Event - Stopped
20.10.2021 11:21:58 Log state changes to stoped, reason: Error
20.10.2021 11:21:58 Log Handle disconnect for reason Error error:ManagementInterfaceNotAvailable
20.10.2021 11:21:58 Debug Debug: config connect called
20.10.2021 11:21:59 Log DisconnectReason set to NoDisconnect in connect_thread
20.10.2021 11:21:59 Log Debug: connect_thread started
20.10.2021 11:21:59 Log State Change Event - Initializing
20.10.2021 11:21:59 Log Waiting for system to get ready..
20.10.2021 11:22:00 Log Waiting for OpenVPN.exe to get ready
20.10.2021 11:22:00 Log OpenVPN.exe ready
20.10.2021 11:22:00 Log Checking firewall and DNS leak protection settings
Das ist die Meldung, wenn ich versuche per OpenVPN eine Verbindung aufzunehmen. Egal welchen Server ich anklicke. Es ist immer wieder das Gleiche.
Ich weiß echt nicht mehr weiter.
Netzwerk wurde zurückgesetzt. Alle Dateien gelöscht.
Liebe Grüße
Liebe Grüße
