Mon Jan 20 08:51:03 2020 us=934687 Initialization Sequence Completed
Mon Jan 20 08:54:46 2020 us=965607 [Server_prague.perfect-privacy.com] Inactivity timeout (--ping-restart), restarting
Mon Jan 20 08:54:46 2020 us=965914 TCP/UDP: Closing socket
Mon Jan 20 08:54:46 2020 us=965992 SIGUSR1[soft,ping-restart] received, process restarting
Mon Jan 20 08:54:46 2020 us=966096 Restart pause, 5 second(s)
Mon Jan 20 08:54:51 2020 us=966247 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mon Jan 20 08:54:51 2020 us=966327 Re-using SSL/TLS context
Mon Jan 20 08:54:51 2020 us=966367 LZO compression initialized
Mon Jan 20 08:54:51 2020 us=966474 Control Channel MTU parms [ L:1604 D:1138 EF:112 EB:0 ET:0 EL:3 ]
Mon Jan 20 08:54:51 2020 us=966540 Socket Buffers: R=[87380->262144] S=[16384->262144]
Mon Jan 20 08:54:51 2020 us=966569 TCP/UDP: Preserving recently used remote address: [AF_INET]195.138.249.2:1152
Mon Jan 20 08:54:51 2020 us=966598 Data Channel MTU parms [ L:1604 D:1450 EF:104 EB:143 ET:0 EL:3 AF:3/1 ]
Mon Jan 20 08:54:51 2020 us=966644 Local Options String: 'V4,dev-type tun,link-mtu 1604,tun-mtu 1500,proto TCPv4_CLIENT,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA512,keysize 256,tls-auth,key-method 2,tls-client'
Mon Jan 20 08:54:51 2020 us=966669 Expected Remote Options String: 'V4,dev-type tun,link-mtu 1604,tun-mtu 1500,proto TCPv4_SERVER,comp-lzo,keydir 0,cipher AES-256-CBC,auth SHA512,keysize 256,tls-auth,key-method 2,tls-server'
Mon Jan 20 08:54:51 2020 us=966701 Local Options hash (VER=V4): 'c19f87b0'
Mon Jan 20 08:54:51 2020 us=966721 Expected Remote Options hash (VER=V4): 'eda38e81'
Mon Jan 20 08:54:51 2020 us=966749 Attempting to establish TCP connection with [AF_INET]195.138.249.2:1152 [nonblock]
^CMon Jan 20 08:54:57 2020 us=498089 TCP/UDP: Closing socket
Mon Jan 20 08:54:57 2020 us=498131 Closing TUN/TAP interface
Mon Jan 20 08:54:57 2020 us=498146 /sbin/ip addr del dev tun1 10.1.149.245/24
Mon Jan 20 08:54:57 2020 us=550343 updown.sh tun1 1500 1604 10.1.149.245 255.255.255.0 init
updown.sh: STARTED
updown.sh: hop number: 2 (default: 1)
updown.sh: gateway of previous hop: 10.1.161.3 (default: local gateway)
updown.sh: local gateway:
updown.sh: VPN: int. IP address:
updown.sh: VPN: netmask:
updown.sh: VPN: gateway:
updown.sh: VPN: public IP address:
updown.sh: ERROR: ('route_vpn_gateway') is not an IPv4 address
updown.sh: ABORT
Mon Jan 20 08:54:57 2020 us=555423 WARNING: Failed running command (--up/--down): external program exited with error status: 1
Mon Jan 20 08:54:57 2020 us=555479 Exiting due to fatal error
