Kann seit heute keine Verbindung mehr herstellen
welcome
Hallo
Wollte mich gerade verbinden, klappt aber leider nicht.
Ich weiß nicht woran es liegen könnte. Das Problem hatte ich vorher nie.
Log:
14.08.2015 10:52:30   Debug  Debug: Serviceconnection Disconnect called
14.08.2015 10:52:30   Debug  ServiceConnection Disconnect statechange to VPNConnectionState.Stopped, was Stopped
14.08.2015 10:52:50   Debug  Debug: Serviceconnection Disconnect called
14.08.2015 10:52:50   Debug  ServiceConnection Disconnect statechange to VPNConnectionState.Stopped, was Stopped
14.08.2015 10:53:11   Debug  Debug: Serviceconnection Disconnect called
14.08.2015 10:53:11   Debug  ServiceConnection Disconnect statechange to VPNConnectionState.Stopped, was Stopped
14.08.2015 11:03:03   Debug  Debug: config connect called,  startupDelay + 0
14.08.2015 11:03:03   Log  DisconnectReason set to NoDisconnect in connect_thread
14.08.2015 11:03:03   Log  Debug: connect_thread started
14.08.2015 11:03:03   Debug  PreConnect called
14.08.2015 11:03:03   Debug  CheckState(VpnConnectionState.Initializing) done
14.08.2015 11:03:03   Debug  ChangeState(VpnConnectionState.Initializing); done
14.08.2015 11:03:03   Log  State Change Event - Initializing
14.08.2015 11:03:03   Log  hangtimer reset calling in statechange to init
14.08.2015 11:03:03   Log  Waiting for OpenVPN.exe to get ready
14.08.2015 11:03:03   Log  OpenVPN.exe ready
14.08.2015 11:03:03   Log  Checking firewall and DNS leak protection settings
14.08.2015 11:03:04   Log  Waiting for network to get ready
14.08.2015 11:03:08   Debug  Debug: Serviceconnection connect called
14.08.2015 11:03:08   Debug  connectthread exiting4
14.08.2015 11:03:09   Management  Connecting to management interface 127.0.0.1:11218
14.08.2015 11:03:09   Log  MANAGEMENT: CMD 'state on'
14.08.2015 11:03:09   Log  MANAGEMENT: CMD 'hold release'
14.08.2015 11:03:09   Log  MANAGEMENT: CMD 'username 'Auth' "<Username Removed>"'
14.08.2015 11:03:10   Log  MANAGEMENT: CMD 'password [...]'
14.08.2015 11:03:10   Log  NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
14.08.2015 11:03:10   Log  Deprecated TLS cipher name 'DHE-RSA-AES256-GCM-SHA384', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-GCM-SHA384'
14.08.2015 11:03:10   Log  Deprecated TLS cipher name 'DHE-RSA-AES256-SHA256', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-CBC-SHA256'
14.08.2015 11:03:10   Log  Deprecated TLS cipher name 'DHE-RSA-AES128-GCM-SHA256', please use IANA name 'TLS-DHE-RSA-WITH-AES-128-GCM-SHA256'
14.08.2015 11:03:10   Log  Deprecated TLS cipher name 'DHE-RSA-AES128-SHA256', please use IANA name 'TLS-DHE-RSA-WITH-AES-128-CBC-SHA256'
14.08.2015 11:03:10   Log  Deprecated TLS cipher name 'DHE-RSA-CAMELLIA256-SHA', please use IANA name 'TLS-DHE-RSA-WITH-CAMELLIA-256-CBC-SHA'
14.08.2015 11:03:10   Log  Deprecated TLS cipher name 'DHE-RSA-AES256-SHA', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-CBC-SHA'
14.08.2015 11:03:10   Log  Deprecated TLS cipher name 'DHE-RSA-CAMELLIA128-SHA', please use IANA name 'TLS-DHE-RSA-WITH-CAMELLIA-128-CBC-SHA'
14.08.2015 11:03:10   Log  Deprecated TLS cipher name 'DHE-RSA-AES128-SHA', please use IANA name 'TLS-DHE-RSA-WITH-AES-128-CBC-SHA'
14.08.2015 11:03:10   Log  Deprecated TLS cipher name 'CAMELLIA256-SHA', please use IANA name 'TLS-RSA-WITH-CAMELLIA-256-CBC-SHA'
14.08.2015 11:03:10   Log  Deprecated TLS cipher name 'AES256-SHA', please use IANA name 'TLS-RSA-WITH-AES-256-CBC-SHA'
14.08.2015 11:03:10   Log  Deprecated TLS cipher name 'CAMELLIA128-SHA', please use IANA name 'TLS-RSA-WITH-CAMELLIA-128-CBC-SHA'
14.08.2015 11:03:10   Log  Deprecated TLS cipher name 'AES128-SHA', please use IANA name 'TLS-RSA-WITH-AES-128-CBC-SHA'
14.08.2015 11:03:10   Log  Control Channel Authentication: using 'Steinsel_ta.key' as a OpenVPN static key file
14.08.2015 11:03:10   Log  Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
14.08.2015 11:03:10   Log  Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
14.08.2015 11:03:10   Log  LZO compression initialized
14.08.2015 11:03:10   Log  Control Channel MTU parms [ L:1606 D:210 EF:110 EB:0 ET:0 EL:3 ]
14.08.2015 11:03:10   Log  Socket Buffers: R=[8192->8192] S=[8192->8192]
14.08.2015 11:03:10   Log  MANAGEMENT: >STATE:1439542990,RESOLVE,,,
14.08.2015 11:03:10   Log  hangtimer reset calling in statechange to init
14.08.2015 11:03:10   State  RESOLVE
14.08.2015 11:03:10   Log  Data Channel MTU parms [ L:1606 D:1300 EF:106 EB:143 ET:0 EL:3 AF:3/1 ]
14.08.2015 11:03:10   Log  Fragmentation MTU parms [ L:1606 D:1300 EF:105 EB:143 ET:1 EL:3 AF:3/1 ]
14.08.2015 11:03:10   Log  Local Options String: 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 1,cipher AES-256-CBC,auth SHA512,keysize 256,tls-auth,key-method 2,tls-client'
14.08.2015 11:03:10   Log  Expected Remote Options String: 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 0,cipher AES-256-CBC,auth SHA512,keysize 256,tls-auth,key-method 2,tls-server'
14.08.2015 11:03:10   Log  Local Options hash (VER=V4): '73c06b87'
14.08.2015 11:03:10   Log  Expected Remote Options hash (VER=V4): 'ad1c1209'
14.08.2015 11:03:10   Log  UDPv4 link local: [undef]
14.08.2015 11:03:10   Log  UDPv4 link remote: [AF_INET]94.242.243.162:1151
14.08.2015 11:03:10   Log  MANAGEMENT: >STATE:1439542990,WAIT,,,
14.08.2015 11:03:10   State  WAIT
14.08.2015 11:03:10   Log  MANAGEMENT: >STATE:1439542990,AUTH,,,
14.08.2015 11:03:11   Log  hangtimer reset calling in statechange to init
14.08.2015 11:03:11   State  AUTH
14.08.2015 11:03:11   Log  TLS: Initial packet from [AF_INET]94.242.243.162:1151, sid=16840f90 f1518d63
14.08.2015 11:03:11   Log  WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
14.08.2015 11:03:11   Log  VERIFY OK: depth=1, C=NZ, ST=Wellington, L=Johnsonville, O=perfect-privacy, CN=perfect-privacy, emailAddress=admin@perfect-privacy.com
14.08.2015 11:03:11   Log  VERIFY OK: nsCertType=SERVER
14.08.2015 11:03:11   Log  VERIFY OK: depth=0, C=NZ, ST=Wellington, O=perfect-privacy, CN=server, emailAddress=admin@perfect-privacy.com
14.08.2015 11:03:11   Log  Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
14.08.2015 11:03:11   Log  Data Channel Encrypt: Using 512 bit message hash 'SHA512' for HMAC authentication
14.08.2015 11:03:11   Log  Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
14.08.2015 11:03:11   Log  Data Channel Decrypt: Using 512 bit message hash 'SHA512' for HMAC authentication
14.08.2015 11:03:11   Log  Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-CAMELLIA256-SHA, 4096 bit RSA
14.08.2015 11:03:11   Log  [server] Peer Connection Initiated with [AF_INET]94.242.243.162:1151
14.08.2015 11:03:12   Log  MANAGEMENT: >STATE:1439542992,GET_CONFIG,,,
14.08.2015 11:03:12   Log  hangtimer reset calling in statechange to init
14.08.2015 11:03:12   State  GET_CONFIG
14.08.2015 11:03:13   Log  SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
14.08.2015 11:03:13   Log  PUSH: Received control message: 'PUSH_REPLY,dhcp-option DNS 31.204.150.106,dhcp-option DNS 78.129.180.33,redirect-gateway def1,sndbuf 131072,rcvbuf 131072,route-gateway 10.14.12.1,topology subnet,ping 10,ping-restart 120,ifconfig 10.14.12.7 255.255.255.128'
14.08.2015 11:03:13   Log  OPTIONS IMPORT: timers and/or timeouts modified
14.08.2015 11:03:13   Log  OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
14.08.2015 11:03:13   Log  Socket Buffers: R=[8192->131072] S=[8192->131072]
14.08.2015 11:03:13   Log  OPTIONS IMPORT: --ifconfig/up options modified
14.08.2015 11:03:13   Log  OPTIONS IMPORT: route options modified
14.08.2015 11:03:13   Log  OPTIONS IMPORT: route-related options modified
14.08.2015 11:03:13   Log  OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
14.08.2015 11:03:13   Log  There are no TAP-Windows adapters on this system.  You should be able to create a TAP-Windows adapter by going to Start -> All Programs -> TAP-Windows -> Utilities -> Add a new TAP-Windows virtual ethernet adapter.
14.08.2015 11:03:13   Error  There are no TAP-Windows adapters on this system.  You should be able to create a TAP-Windows adapter by going to Start -> All Programs -> TAP-Windows -> Utilities -> Add a new TAP-Windows virtual ethernet adapter.
14.08.2015 11:03:13   Management  Disconnecting from management interface
14.08.2015 11:03:13   Debug  Error in connection called
14.08.2015 11:03:14   Log  State Change Event - Error
14.08.2015 11:03:14   Log  error handler is setting disconnect reasond to error!
14.08.2015 11:03:14   Management  Disconnecting from management interface
14.08.2015 11:03:14   Debug  Debug:error to stopped
14.08.2015 11:03:14   Log  State Change Event - Stopped
14.08.2015 11:03:14   Log  state changes to stoped, reason: Error
14.08.2015 11:03:14   Log  Handle disconnect for reason Error error:NoTapAdapters
14.08.2015 11:03:14   Error  Tunnel Steinsel Disconnect Called Reason:WaitGlobalAction but disconnect reason already is Error
14.08.2015 11:03:18   Debug  Debug: config connect called,  startupDelay + 4000
14.08.2015 11:03:18   Log  DisconnectReason set to NoDisconnect in connect_thread
14.08.2015 11:03:18   Log  Debug: connect_thread started
14.08.2015 11:03:19   Debug  PreConnect called
14.08.2015 11:03:19   Debug  CheckState(VpnConnectionState.Initializing) done
14.08.2015 11:03:19   Log  State Change Event - Initializing
14.08.2015 11:03:19   Log  hangtimer reset calling in statechange to init
14.08.2015 11:03:19   Debug  ChangeState(VpnConnectionState.Initializing); done
14.08.2015 11:03:19   Log  Waiting for system to get ready..
14.08.2015 11:03:23   Log  Waiting for OpenVPN.exe to get ready
14.08.2015 11:03:24   Log  OpenVPN.exe ready
14.08.2015 11:03:24   Log  Checking firewall and DNS leak protection settings
14.08.2015 11:03:24   Log  Waiting for network to get ready
14.08.2015 11:03:28   Debug  Debug: Serviceconnection connect called
14.08.2015 11:03:28   Debug  connectthread exiting4
14.08.2015 11:03:29   Management  Connecting to management interface 127.0.0.1:11218
14.08.2015 11:03:29   Log  MANAGEMENT: CMD 'state on'
14.08.2015 11:03:29   Log  MANAGEMENT: CMD 'hold release'
14.08.2015 11:03:29   Log  MANAGEMENT: CMD 'username 'Auth' "<Username Removed>"'
14.08.2015 11:03:30   Log  MANAGEMENT: CMD 'password [...]'
14.08.2015 11:03:30   Log  NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
14.08.2015 11:03:30   Log  Deprecated TLS cipher name 'DHE-RSA-AES256-GCM-SHA384', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-GCM-SHA384'
14.08.2015 11:03:30   Log  Deprecated TLS cipher name 'DHE-RSA-AES256-SHA256', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-CBC-SHA256'
14.08.2015 11:03:30   Log  Deprecated TLS cipher name 'DHE-RSA-AES128-GCM-SHA256', please use IANA name 'TLS-DHE-RSA-WITH-AES-128-GCM-SHA256'
14.08.2015 11:03:30   Log  Deprecated TLS cipher name 'DHE-RSA-AES128-SHA256', please use IANA name 'TLS-DHE-RSA-WITH-AES-128-CBC-SHA256'
14.08.2015 11:03:30   Log  Deprecated TLS cipher name 'DHE-RSA-CAMELLIA256-SHA', please use IANA name 'TLS-DHE-RSA-WITH-CAMELLIA-256-CBC-SHA'
14.08.2015 11:03:30   Log  Deprecated TLS cipher name 'DHE-RSA-AES256-SHA', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-CBC-SHA'
14.08.2015 11:03:30   Log  Deprecated TLS cipher name 'DHE-RSA-CAMELLIA128-SHA', please use IANA name 'TLS-DHE-RSA-WITH-CAMELLIA-128-CBC-SHA'
14.08.2015 11:03:30   Log  Deprecated TLS cipher name 'DHE-RSA-AES128-SHA', please use IANA name 'TLS-DHE-RSA-WITH-AES-128-CBC-SHA'
14.08.2015 11:03:30   Log  Deprecated TLS cipher name 'CAMELLIA256-SHA', please use IANA name 'TLS-RSA-WITH-CAMELLIA-256-CBC-SHA'
14.08.2015 11:03:30   Log  Deprecated TLS cipher name 'AES256-SHA', please use IANA name 'TLS-RSA-WITH-AES-256-CBC-SHA'
14.08.2015 11:03:30   Log  Deprecated TLS cipher name 'CAMELLIA128-SHA', please use IANA name 'TLS-RSA-WITH-CAMELLIA-128-CBC-SHA'
14.08.2015 11:03:30   Log  Deprecated TLS cipher name 'AES128-SHA', please use IANA name 'TLS-RSA-WITH-AES-128-CBC-SHA'
14.08.2015 11:03:30   Log  Control Channel Authentication: using 'Steinsel_ta.key' as a OpenVPN static key file
14.08.2015 11:03:30   Log  Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
14.08.2015 11:03:30   Log  Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
14.08.2015 11:03:30   Log  LZO compression initialized
14.08.2015 11:03:30   Log  Control Channel MTU parms [ L:1606 D:210 EF:110 EB:0 ET:0 EL:3 ]
14.08.2015 11:03:30   Log  Socket Buffers: R=[8192->8192] S=[8192->8192]
14.08.2015 11:03:30   Log  MANAGEMENT: >STATE:1439543010,RESOLVE,,,
14.08.2015 11:03:30   Log  hangtimer reset calling in statechange to init
14.08.2015 11:03:30   State  RESOLVE
14.08.2015 11:03:30   Log  Data Channel MTU parms [ L:1606 D:1300 EF:106 EB:143 ET:0 EL:3 AF:3/1 ]
14.08.2015 11:03:30   Log  Fragmentation MTU parms [ L:1606 D:1300 EF:105 EB:143 ET:1 EL:3 AF:3/1 ]
14.08.2015 11:03:30   Log  Local Options String: 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 1,cipher AES-256-CBC,auth SHA512,keysize 256,tls-auth,key-method 2,tls-client'
14.08.2015 11:03:30   Log  Expected Remote Options String: 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 0,cipher AES-256-CBC,auth SHA512,keysize 256,tls-auth,key-method 2,tls-server'
14.08.2015 11:03:30   Log  Local Options hash (VER=V4): '73c06b87'
14.08.2015 11:03:30   Log  Expected Remote Options hash (VER=V4): 'ad1c1209'
14.08.2015 11:03:30   Log  UDPv4 link local: [undef]
14.08.2015 11:03:30   Log  UDPv4 link remote: [AF_INET]94.242.243.162:149
14.08.2015 11:03:30   Log  MANAGEMENT: >STATE:1439543010,WAIT,,,
14.08.2015 11:03:31   State  WAIT
14.08.2015 11:03:31   Log  MANAGEMENT: >STATE:1439543010,AUTH,,,
14.08.2015 11:03:31   Log  hangtimer reset calling in statechange to init
14.08.2015 11:03:31   State  AUTH
14.08.2015 11:03:31   Log  TLS: Initial packet from [AF_INET]94.242.243.162:149, sid=94357591 c54c1b12
14.08.2015 11:03:31   Log  WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
14.08.2015 11:03:31   Log  VERIFY OK: depth=1, C=NZ, ST=Wellington, L=Johnsonville, O=perfect-privacy, CN=perfect-privacy, emailAddress=admin@perfect-privacy.com
14.08.2015 11:03:31   Log  VERIFY OK: nsCertType=SERVER
14.08.2015 11:03:31   Log  VERIFY OK: depth=0, C=NZ, ST=Wellington, O=perfect-privacy, CN=server, emailAddress=admin@perfect-privacy.com
14.08.2015 11:03:31   Log  Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
14.08.2015 11:03:31   Log  Data Channel Encrypt: Using 512 bit message hash 'SHA512' for HMAC authentication
14.08.2015 11:03:31   Log  Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
14.08.2015 11:03:31   Log  Data Channel Decrypt: Using 512 bit message hash 'SHA512' for HMAC authentication
14.08.2015 11:03:31   Log  Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-CAMELLIA256-SHA, 4096 bit RSA
14.08.2015 11:03:31   Log  [server] Peer Connection Initiated with [AF_INET]94.242.243.162:149
14.08.2015 11:03:32   Log  MANAGEMENT: >STATE:1439543012,GET_CONFIG,,,
14.08.2015 11:03:32   Log  hangtimer reset calling in statechange to init
14.08.2015 11:03:33   State  GET_CONFIG
14.08.2015 11:03:33   Log  SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
14.08.2015 11:03:33   Log  PUSH: Received control message: 'PUSH_REPLY,dhcp-option DNS 31.204.152.102,dhcp-option DNS 37.48.74.75,redirect-gateway def1,sndbuf 131072,rcvbuf 131072,route-gateway 10.14.12.129,topology subnet,ping 10,ping-restart 120,ifconfig 10.14.12.137 255.255.255.128'
14.08.2015 11:03:33   Log  OPTIONS IMPORT: timers and/or timeouts modified
14.08.2015 11:03:33   Log  OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
14.08.2015 11:03:33   Log  Socket Buffers: R=[8192->131072] S=[8192->131072]
14.08.2015 11:03:33   Log  OPTIONS IMPORT: --ifconfig/up options modified
14.08.2015 11:03:33   Log  OPTIONS IMPORT: route options modified
14.08.2015 11:03:33   Log  OPTIONS IMPORT: route-related options modified
14.08.2015 11:03:33   Log  OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
14.08.2015 11:03:33   Log  There are no TAP-Windows adapters on this system.  You should be able to create a TAP-Windows adapter by going to Start -> All Programs -> TAP-Windows -> Utilities -> Add a new TAP-Windows virtual ethernet adapter.
14.08.2015 11:03:33   Error  There are no TAP-Windows adapters on this system.  You should be able to create a TAP-Windows adapter by going to Start -> All Programs -> TAP-Windows -> Utilities -> Add a new TAP-Windows virtual ethernet adapter.
14.08.2015 11:03:33   Management  Disconnecting from management interface
14.08.2015 11:03:33   Debug  Error in connection called
14.08.2015 11:03:34   Log  State Change Event - Error
14.08.2015 11:03:34   Log  error handler is setting disconnect reasond to error!
14.08.2015 11:03:34   Management  Disconnecting from management interface
14.08.2015 11:03:34   Debug  Debug:error to stopped
14.08.2015 11:03:34   Log  State Change Event - Stopped
14.08.2015 11:03:34   Log  state changes to stoped, reason: Error
14.08.2015 11:03:34   Log  Handle disconnect for reason Error error:NoTapAdapters
14.08.2015 11:03:34   Error  Tunnel Steinsel Disconnect Called Reason:WaitGlobalAction but disconnect reason already is Error
14.08.2015 11:03:38   Debug  Debug: config connect called,  startupDelay + 4000
14.08.2015 11:03:39   Log  DisconnectReason set to NoDisconnect in connect_thread
14.08.2015 11:03:39   Log  Debug: connect_thread started
14.08.2015 11:03:39   Debug  PreConnect called
14.08.2015 11:03:39   Debug  CheckState(VpnConnectionState.Initializing) done
14.08.2015 11:03:39   Log  State Change Event - Initializing
14.08.2015 11:03:39   Log  hangtimer reset calling in statechange to init
14.08.2015 11:03:39   Debug  ChangeState(VpnConnectionState.Initializing); done
14.08.2015 11:03:39   Log  Waiting for system to get ready..
14.08.2015 11:03:43   Log  Waiting for OpenVPN.exe to get ready
14.08.2015 11:03:44   Log  OpenVPN.exe ready
14.08.2015 11:03:44   Log  Checking firewall and DNS leak protection settings
14.08.2015 11:03:44   Log  Waiting for network to get ready
14.08.2015 11:03:48   Debug  Debug: Serviceconnection connect called
14.08.2015 11:03:48   Debug  connectthread exiting4
14.08.2015 11:03:49   Management  Connecting to management interface 127.0.0.1:11218
14.08.2015 11:03:49   Log  MANAGEMENT: CMD 'state on'
14.08.2015 11:03:49   Log  MANAGEMENT: CMD 'hold release'
14.08.2015 11:03:49   Log  MANAGEMENT: CMD 'username 'Auth' "<Username Removed>"'
14.08.2015 11:03:50   Log  MANAGEMENT: CMD 'password [...]'
14.08.2015 11:03:50   Log  NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
14.08.2015 11:03:50   Log  Deprecated TLS cipher name 'DHE-RSA-AES256-GCM-SHA384', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-GCM-SHA384'
14.08.2015 11:03:50   Log  Deprecated TLS cipher name 'DHE-RSA-AES256-SHA256', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-CBC-SHA256'
14.08.2015 11:03:50   Log  Deprecated TLS cipher name 'DHE-RSA-AES128-GCM-SHA256', please use IANA name 'TLS-DHE-RSA-WITH-AES-128-GCM-SHA256'
14.08.2015 11:03:50   Log  Deprecated TLS cipher name 'DHE-RSA-AES128-SHA256', please use IANA name 'TLS-DHE-RSA-WITH-AES-128-CBC-SHA256'
14.08.2015 11:03:50   Log  Deprecated TLS cipher name 'DHE-RSA-CAMELLIA256-SHA', please use IANA name 'TLS-DHE-RSA-WITH-CAMELLIA-256-CBC-SHA'
14.08.2015 11:03:50   Log  Deprecated TLS cipher name 'DHE-RSA-AES256-SHA', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-CBC-SHA'
14.08.2015 11:03:50   Log  Deprecated TLS cipher name 'DHE-RSA-CAMELLIA128-SHA', please use IANA name 'TLS-DHE-RSA-WITH-CAMELLIA-128-CBC-SHA'
14.08.2015 11:03:50   Log  Deprecated TLS cipher name 'DHE-RSA-AES128-SHA', please use IANA name 'TLS-DHE-RSA-WITH-AES-128-CBC-SHA'
14.08.2015 11:03:50   Log  Deprecated TLS cipher name 'CAMELLIA256-SHA', please use IANA name 'TLS-RSA-WITH-CAMELLIA-256-CBC-SHA'
14.08.2015 11:03:50   Log  Deprecated TLS cipher name 'AES256-SHA', please use IANA name 'TLS-RSA-WITH-AES-256-CBC-SHA'
14.08.2015 11:03:50   Log  Deprecated TLS cipher name 'CAMELLIA128-SHA', please use IANA name 'TLS-RSA-WITH-CAMELLIA-128-CBC-SHA'
14.08.2015 11:03:50   Log  Deprecated TLS cipher name 'AES128-SHA', please use IANA name 'TLS-RSA-WITH-AES-128-CBC-SHA'
14.08.2015 11:03:50   Log  Control Channel Authentication: using 'Steinsel_ta.key' as a OpenVPN static key file
14.08.2015 11:03:50   Log  Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
14.08.2015 11:03:50   Log  Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
14.08.2015 11:03:50   Log  LZO compression initialized
14.08.2015 11:03:50   Log  Control Channel MTU parms [ L:1606 D:210 EF:110 EB:0 ET:0 EL:3 ]
14.08.2015 11:03:50   Log  Socket Buffers: R=[8192->8192] S=[8192->8192]
14.08.2015 11:03:50   Log  MANAGEMENT: >STATE:1439543030,RESOLVE,,,
14.08.2015 11:03:50   Log  hangtimer reset calling in statechange to init
14.08.2015 11:03:50   State  RESOLVE
14.08.2015 11:03:50   Log  Data Channel MTU parms [ L:1606 D:1300 EF:106 EB:143 ET:0 EL:3 AF:3/1 ]
14.08.2015 11:03:50   Log  Fragmentation MTU parms [ L:1606 D:1300 EF:105 EB:143 ET:1 EL:3 AF:3/1 ]
14.08.2015 11:03:50   Log  Local Options String: 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 1,cipher AES-256-CBC,auth SHA512,keysize 256,tls-auth,key-method 2,tls-client'
14.08.2015 11:03:50   Log  Expected Remote Options String: 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 0,cipher AES-256-CBC,auth SHA512,keysize 256,tls-auth,key-method 2,tls-server'
14.08.2015 11:03:50   Log  Local Options hash (VER=V4): '73c06b87'
14.08.2015 11:03:50   Log  Expected Remote Options hash (VER=V4): 'ad1c1209'
14.08.2015 11:03:50   Log  UDPv4 link local: [undef]
14.08.2015 11:03:50   Log  UDPv4 link remote: [AF_INET]94.242.243.66:1149
14.08.2015 11:03:50   Log  MANAGEMENT: >STATE:1439543030,WAIT,,,
14.08.2015 11:03:51   Log  hangtimer reset calling in statechange to init
14.08.2015 11:03:51   State  WAIT
14.08.2015 11:03:51   Log  MANAGEMENT: >STATE:1439543030,AUTH,,,
14.08.2015 11:03:51   State  AUTH
14.08.2015 11:03:51   Log  TLS: Initial packet from [AF_INET]94.242.243.66:1149, sid=675fe177 dfa86430
14.08.2015 11:03:51   Log  WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
14.08.2015 11:03:51   Log  VERIFY OK: depth=1, C=NZ, ST=Wellington, L=Johnsonville, O=perfect-privacy, CN=perfect-privacy, emailAddress=admin@perfect-privacy.com
14.08.2015 11:03:51   Log  VERIFY OK: nsCertType=SERVER
14.08.2015 11:03:51   Log  VERIFY OK: depth=0, C=NZ, ST=Wellington, O=perfect-privacy, CN=server, emailAddress=admin@perfect-privacy.com
14.08.2015 11:03:51   Log  Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
14.08.2015 11:03:51   Log  Data Channel Encrypt: Using 512 bit message hash 'SHA512' for HMAC authentication
14.08.2015 11:03:51   Log  Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
14.08.2015 11:03:51   Log  Data Channel Decrypt: Using 512 bit message hash 'SHA512' for HMAC authentication
14.08.2015 11:03:51   Log  Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-CAMELLIA256-SHA, 4096 bit RSA
14.08.2015 11:03:51   Log  [server] Peer Connection Initiated with [AF_INET]94.242.243.66:1149
14.08.2015 11:03:52   Log  MANAGEMENT: >STATE:1439543032,GET_CONFIG,,,
14.08.2015 11:03:52   Log  hangtimer reset calling in statechange to init
14.08.2015 11:03:53   State  GET_CONFIG
14.08.2015 11:03:53   Log  SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
14.08.2015 11:03:53   Log  PUSH: Received control message: 'PUSH_REPLY,dhcp-option DNS 31.204.150.106,dhcp-option DNS 178.162.194.30,redirect-gateway def1,sndbuf 131072,rcvbuf 131072,route-gateway 10.14.21.1,topology subnet,ping 10,ping-restart 120,ifconfig 10.14.21.3 255.255.255.128'
14.08.2015 11:03:53   Log  OPTIONS IMPORT: timers and/or timeouts modified
14.08.2015 11:03:53   Log  OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
14.08.2015 11:03:53   Log  Socket Buffers: R=[8192->131072] S=[8192->131072]
14.08.2015 11:03:53   Log  OPTIONS IMPORT: --ifconfig/up options modified
14.08.2015 11:03:54   Log  OPTIONS IMPORT: route options modified
14.08.2015 11:03:54   Log  OPTIONS IMPORT: route-related options modified
14.08.2015 11:03:54   Log  OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
14.08.2015 11:03:54   Log  There are no TAP-Windows adapters on this system.  You should be able to create a TAP-Windows adapter by going to Start -> All Programs -> TAP-Windows -> Utilities -> Add a new TAP-Windows virtual ethernet adapter.
14.08.2015 11:03:54   Error  There are no TAP-Windows adapters on this system.  You should be able to create a TAP-Windows adapter by going to Start -> All Programs -> TAP-Windows -> Utilities -> Add a new TAP-Windows virtual ethernet adapter.
14.08.2015 11:03:54   Management  Disconnecting from management interface
14.08.2015 11:03:54   Debug  Error in connection called
14.08.2015 11:03:54   Log  State Change Event - Error
14.08.2015 11:03:54   Log  error handler is setting disconnect reasond to error!
14.08.2015 11:03:54   Debug  Debug:error to stopped
14.08.2015 11:03:54   Log  State Change Event - Stopped
14.08.2015 11:03:54   Log  state changes to stoped, reason: Error
14.08.2015 11:03:54   Log  Handle disconnect for reason Error error:NoTapAdapters
14.08.2015 11:03:54   Error  Tunnel Steinsel Disconnect Called Reason:WaitGlobalAction but disconnect reason already is Error
14.08.2015 11:03:58   Debug  Debug: config connect called,  startupDelay + 4000
14.08.2015 11:03:59   Log  DisconnectReason set to NoDisconnect in connect_thread
14.08.2015 11:03:59   Log  Debug: connect_thread started
14.08.2015 11:03:59   Debug  PreConnect called
14.08.2015 11:03:59   Debug  CheckState(VpnConnectionState.Initializing) done
14.08.2015 11:03:59   Log  State Change Event - Initializing
14.08.2015 11:03:59   Log  hangtimer reset calling in statechange to init
14.08.2015 11:03:59   Debug  ChangeState(VpnConnectionState.Initializing); done
14.08.2015 11:03:59   Debug  Waiting for user decision
14.08.2015 11:03:59   Log  hangtimer reset calling connect_thread
14.08.2015 11:04:01   Debug  User decided to disconnect
14.08.2015 11:04:01   Log  Tunnel Steinsel Disconnect Called Reason:UserClicked
14.08.2015 11:04:01   Debug  Debug: Serviceconnection Disconnect called
14.08.2015 11:04:01   Log  State Change Event - Stopping
14.08.2015 11:04:01   Log  hangtimer reset calling in statechange to stopping
14.08.2015 11:04:01   Debug  killConnection called
14.08.2015 11:04:01   Debug  calling SendRestart now
14.08.2015 11:04:01   Management  SendRestart called
14.08.2015 11:04:01   Debug  SendRestart done
14.08.2015 11:04:01   Management  Sending signal to close connection
14.08.2015 11:04:01   Debug  SendDisconnect done
14.08.2015 11:04:01   Management  Disconnecting from management interface
14.08.2015 11:04:01   Debug  DisconnectLogic done
14.08.2015 11:04:01   Debug  killConnection calling stopOpenVPNBinary
14.08.2015 11:04:02   Debug  killConnection statechange to VPNConnectionState.Stopped
14.08.2015 11:04:02   Log  State Change Event - Stopped
14.08.2015 11:04:02   Log  state changes to stoped, reason: UserClicked
14.08.2015 11:04:02   Log  Handle disconnect for reason UserClicked error:NoError
Mit freundlichen Grüßen
