´nabend.
seit einiger zeit habe ich im log immer eine fehlermeldung zu stehen. der verbingungsaufbau funktioniert einwandfrei. hier ein logauszug:
13.04.2016 21:13:34 Log env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
13.04.2016 21:13:38 Log TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
13.04.2016 21:13:38 Log Initialization Sequence Completed
13.04.2016 21:13:38 Log MANAGEMENT: >STATE:1460574818,CONNECTED,SUCCESS,10.15.31.247,62.212.82.51
13.04.2016 21:13:38 Log State Change Event - Running
13.04.2016 21:13:44 State CONNECTED
13.04.2016 21:13:44 Log PID_ERR replay-window backtrack occurred [3] [SSL-0] [000_0112] 0:8 0:5 t=1460574824[0] r=[-2,64,15,3,1] sl=[56,8,64,528]
13.04.2016 21:20:01 Log PID_ERR replay-window backtrack occurred [5] [SSL-0] [00000_002>>EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE] 0:630 0:625 t=1460575201[0] r=[-2,64,15,5,1] sl=[10,64,64,528]
13.04.2016 21:33:17 Log PID_ERR replay-window backtrack occurred [10] [SSL-0] [00000000___000666666666666677788999>>>>>>>>>>>>>>>>>>>>>>>>>>>EE] 0:1030 0:1020 t=1460575997[0] r=[0,64,15,10,1] sl=[58,64,64,528]
13.04.2016 22:13:28 Log TLS: soft reset sec=0 bytes=1717562/0 pkts=4758/0
13.04.2016 22:13:29 Log VERIFY OK: depth=1, C=CH, ST=Zug, L=Zug, O=Perfect Privacy, CN=Perfect Privacy, emailAddress=admin@perfect-privacy.com
13.04.2016 22:13:29 Log VERIFY OK: nsCertType=SERVER
13.04.2016 22:13:29 Log VERIFY OK: depth=0, C=CH, ST=Zug, O=Perfect Privacy, CN=server, emailAddress=admin@perfect-privacy.com
13.04.2016 22:13:29 Log Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
13.04.2016 22:13:29 Log Data Channel Encrypt: Using 512 bit message hash 'SHA512' for HMAC authentication
13.04.2016 22:13:29 Log Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
13.04.2016 22:13:29 Log Data Channel Decrypt: Using 512 bit message hash 'SHA512' for HMAC authentication
13.04.2016 22:13:29 Log Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-CAMELLIA256-SHA, 4096 bit RSA
13.04.2016 22:20:27 Log PID_ERR replay-window backtrack occurred [3] [SSL-1] [000_0088EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE] 0:58 0:55 t=1460578827[0] r=[0,64,15,3,1] sl=[6,58,64,528]
13.04.2016 22:29:02 Log PID_ERR replay-window backtrack occurred [5] [SSL-1] [00000_013>>EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE] 0:322 0:317 t=1460579342[0] r=[-3,64,15,5,1] sl=[62,64,64,528]
13.04.2016 23:09:18 Log PID_ERR replay-window backtrack occurred [44] [SSL-1] [0000000000000000000000000000000000000000000__1222222234555555555] 0:10856 0:10812 t=1460581758[0] r=[-1,64,15,44,1] sl=[24,64,64,528]
13.04.2016 23:13:28 Log TLS: tls_process: killed expiring key
13.04.2016 23:13:29 Log TLS: soft reset sec=0 bytes=47557655/0 pkts=58594/0
13.04.2016 23:13:29 Log VERIFY OK: depth=1, C=CH, ST=Zug, L=Zug, O=Perfect Privacy, CN=Perfect Privacy, emailAddress=admin@perfect-privacy.com
13.04.2016 23:13:29 Log VERIFY OK: nsCertType=SERVER
13.04.2016 23:13:29 Log VERIFY OK: depth=0, C=CH, ST=Zug, O=Perfect Privacy, CN=server, emailAddress=admin@perfect-privacy.com
13.04.2016 23:13:30 Log Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
13.04.2016 23:13:30 Log Data Channel Encrypt: Using 512 bit message hash 'SHA512' for HMAC authentication
13.04.2016 23:13:30 Log Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
13.04.2016 23:13:30 Log Data Channel Decrypt: Using 512 bit message hash 'SHA512' for HMAC authentication
13.04.2016 23:13:30 Log Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-CAMELLIA256-SHA, 4096 bit RSA
13.04.2016 23:14:29 Log PID_ERR replay-window backtrack occurred [12] [SSL-2] [000000000000_00] 0:15 0:3 t=1460582069[0] r=[0,64,15,12,1] sl=[49,15,64,528]
13.04.2016 23:15:09 Log PID_ERR replay-window backtrack occurred [18] [SSL-2] [00000000000000000__008888889999999999999999999999999999999999999] 0:4467 0:4449 t=1460582109[0] r=[0,64,15,18,1] sl=[13,64,64,528]
13.04.2016 23:15:25 Log PID_ERR replay-window backtrack occurred [23] [SSL-2] [00000000000000000000000_00067EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE] 0:6166 0:6143 t=1460582125[0] r=[0,64,15,23,1] sl=[42,64,64,528]
13.04.2016 23:19:05 Log PID_ERR replay-window backtrack occurred [27] [SSL-2] [000000000000000000000000000_01>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>] 0:44323 0:44296 t=1460582345[0] r=[-1,64,15,27,1] sl=[29,64,64,528]
13.04.2016 23:26:41 Log PID_ERR replay-window backtrack occurred [31] [SSL-2] [0000000000000000000000000000000_00666666666666666666666666666666] 0:118644 0:118613 t=1460582801[0] r=[0,64,15,31,1] sl=[12,64,64,528]
13.04.2016 23:26:46 Log PID_ERR replay-window backtrack occurred [45] [SSL-2] [00000000000000000000000000000000000000000_____000000005555555555] 0:118946 0:118901 t=1460582806[0] r=[0,64,15,45,1] sl=[30,64,64,528]
13.04.2016 23:26:46 Log PID_ERR replay-window backtrack occurred [54] [SSL-2] [000000000000000000000000000000000000000000000000000____000000000] 0:118956 0:118902 t=1460582806[0] r=[0,64,15,54,1] sl=[20,64,64,528]
13.04.2016 23:26:46 Log PID_ERR replay-window backtrack occurred [65] [SSL-2] [000000000000000000000000000000000000000000000000000000000000000_] 0:118968 0:118903 t=1460582806[0] r=[0,64,15,65,1] sl=[8,64,64,528]
13.04.2016 23:26:46 Log PID_ERR large diff [65] [SSL-2] [000000000000000000000000000000000000000000000000000000000000000_] 0:118968 0:118903 t=1460582806[0] r=[0,64,15,65,1] sl=[8,64,64,528]
13.04.2016 23:26:46 Log PID_ERR replay-window backtrack occurred [88] [SSL-2] [0000000000000000000000000000000000000000000000000000000000000000] 0:118992 0:118904 t=1460582806[0] r=[0,64,15,88,1] sl=[48,64,64,528]
13.04.2016 23:26:46 Log PID_ERR large diff [88] [SSL-2] [0000000000000000000000000000000000000000000000000000000000000000] 0:118992 0:118904 t=1460582806[0] r=[0,64,15,88,1] sl=[48,64,64,528]
13.04.2016 23:26:46 Log PID_ERR large diff [87] [SSL-2] [0000000000000000000000000000000000000000000000000000000000000000] 0:118992 0:118905 t=1460582806[0] r=[0,64,15,88,1] sl=[48,64,64,528]
13.04.2016 23:28:28 Log PID_ERR large diff [71] [SSL-2] [0000000000000000000000000000000000000000000000000000000000000000] 0:138006 0:137935 t=1460582908[0] r=[0,64,15,88,1] sl=[42,64,64,528]
13.04.2016 23:28:28 Log PID_ERR large diff [71] [SSL-2] [0000000000000000000000000000000000000000000000000000000000000000] 0:138007 0:137936 t=1460582908[0] r=[0,64,15,88,1] sl=[41,64,64,528]
14.04.2016 00:13:29 Log TLS: tls_process: killed expiring key
14.04.2016 00:13:30 Log TLS: soft reset sec=0 bytes=735058661/0 pkts=806345/0
14.04.2016 00:13:30 Log PID_ERR replay-window backtrack occurred [3] [TLS_AUTH-0] [00__0EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE] 1460574747:198 1460574747:195 t=1460585610[0] r=[0,64,15,3,1] sl=[58,64,64,528]
14.04.2016 00:13:31 Log VERIFY OK: depth=1, C=CH, ST=Zug, L=Zug, O=Perfect Privacy, CN=Perfect Privacy, emailAddress=admin@perfect-privacy.com
kann hier jemand weiterhelfen? welche ursache hat die fehlermeldung?
thx.
thx.
