Delete route and prevent DNS leaks when using a router. HELP!
Hi folks!
I need a little help. I know how to use batch files to automatically delete my Internet Service Providers Route and to prevent DNS leaks. It has always worked out fine. But now I have fixed a router and that’s where the problems began. Before I had always a static IP configuration, but now it only seems to work with automatic configuration if I want to log in to the Internet. To prevent DNS leaks for example the network configuration must be static not automatic.
1. Can I fix the delete route and DNS leak even though I now have a router? If the answer is yes. How shell I do?
2. Must I fix something on my computer or in the router?
3. If there are ways to fix my issue, can other computers anyway log in to the Internet through the same router I have as before?
Thanks for some answers.
Hi folks!
