connection issues
cris2k
Hi, since i started using Perfect Privacy almost a month ago ive been having problems connecting to any/all servers. Ive tried uninstalling and reinstalling the app etc and nothing appears to help. im running windows 10 pro 64 bit with all updates. the taskbar icon says nottingham: connected waiting for confirmation, i get this with every server i try to connect to. My entire internet is blocked wbile in this state (i get an exclamation mark on the network icon).
Log:
21/05/2019 09:32:03 Log IpSec Connnection Disconnect called
21/05/2019 09:32:03 Log IpSec Connnection Disconnect calling state change to stop
21/05/2019 09:33:52 Log IpSec Connnection Disconnect called
21/05/2019 09:33:52 Log IpSec Connnection Disconnect calling state change to stop
21/05/2019 09:40:13 Debug Debug: config connect called
21/05/2019 09:40:13 Log DisconnectReason set to NoDisconnect in connect_thread
21/05/2019 09:40:13 Log Debug: connect_thread started
21/05/2019 09:40:13 Log State Change Event - Initializing
21/05/2019 09:40:14 Log Waiting for IPSEC device to get ready
21/05/2019 09:40:14 Log IPSEC device ready
21/05/2019 09:40:14 Log Checking firewall and DNS leak protection settings
21/05/2019 09:40:18 Log Waiting for network to get ready
21/05/2019 09:40:18 Log OpenPort
21/05/2019 09:40:18 Log PortOpened
21/05/2019 09:40:18 Log ConnectDevice
21/05/2019 09:40:18 Log DeviceConnected
21/05/2019 09:40:18 Log AllDevicesConnected
21/05/2019 09:40:18 Log Authenticate
21/05/2019 09:40:19 Log AuthNotify
21/05/2019 09:40:19 Log AuthProject
21/05/2019 09:40:19 Log Projected
21/05/2019 09:40:19 Log Authenticated
21/05/2019 09:40:19 Log ApplySettings
21/05/2019 09:40:19 Log Connected
21/05/2019 09:40:19 Management CONNECTED
21/05/2019 09:40:19 Log State Change Event - Running
Edit: I'm using KIS and the app is in the trusted apps list so dont think my av/firewall is blocking it.
