Kevin1980xp1
Hi. For a few months now, certain servers simply refuse to connect at all - I cannot remember on top of my head all of them, for example London or Manchester.
I've ignored this issue for a long time now since I would just connect to another server, like one in Netherlands, thinking that the other servers would eventually get fixed but sadly they haven't. I confirmed that this is not a me issue either - I cannot connect to those servers neither on Windows, nor android, and neither using my ISP or my 4G internet. I've also asked my friend whos american that also uses Perfect Privacy and they also cannot connect to those two servers.
Here are the logs of when trying to connect to London for example. (I've removed some numbers in the logs since I don't know if they are unique to me or not).
It always gets stuck on State: Wait. When connecting to other servers that do work, the logs look exactly the same, with the difference that it does get past State: Wait and actually connects.
12/17/2021 3:35:30 AM Debug Debug: config connect called
12/17/2021 3:35:30 AM Log DisconnectReason set to NoDisconnect in connect_thread
12/17/2021 3:35:30 AM Log Debug: connect_thread started
12/17/2021 3:35:31 AM Log State Change Event - Initializing
12/17/2021 3:35:31 AM Log Waiting for system to get ready..
12/17/2021 3:35:31 AM Log Waiting for OpenVPN.exe to get ready
12/17/2021 3:35:31 AM Log OpenVPN.exe ready
12/17/2021 3:35:31 AM Log Checking firewall and DNS leak protection settings
12/17/2021 3:35:34 AM Log Waiting for network to get ready
12/17/2021 3:35:35 AM Debug Proxy: VpnServer: RemoteIp:
12/17/2021 3:35:35 AM Debug Debug: Serviceconnection connect called
12/17/2021 3:35:36 AM Management Connecting to management interface
12/17/2021 3:35:36 AM Log MANAGEMENT: CMD 'state on'
12/17/2021 3:35:36 AM Log MANAGEMENT: CMD 'hold release'
12/17/2021 3:35:36 AM Log MANAGEMENT: CMD 'username 'Auth' "<Username Removed>"'
12/17/2021 3:35:37 AM Log MANAGEMENT: CMD 'password [...]'
12/17/2021 3:35:37 AM Log NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
12/17/2021 3:35:37 AM Log Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
12/17/2021 3:35:37 AM Log Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
12/17/2021 3:35:37 AM Log Control Channel MTU parms [ ]
12/17/2021 3:35:37 AM Log Data Channel MTU parms [ ]
12/17/2021 3:35:37 AM Log Fragmentation MTU parms [ ]
12/17/2021 3:35:37 AM Log Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 1,cipher AES-256-CBC,auth SHA512,keysize 256,tls-auth,key-method 2,tls-client'
12/17/2021 3:35:37 AM Log Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 0,cipher AES-256-CBC,auth SHA512,keysize 256,tls-auth,key-method 2,tls-server'
12/17/2021 3:35:37 AM Log TCP/UDP: Preserving recently used remote address: [AF_INET]
12/17/2021 3:35:37 AM Log Socket Buffers: R=[65536->65536] S=[65536->65536]
12/17/2021 3:35:37 AM Log UDP link local: (not bound)
12/17/2021 3:35:37 AM Log UDP link remote: [AF_INET]
12/17/2021 3:35:37 AM Log MANAGEMENT: >STATE: ,WAIT,,,,,,
12/17/2021 3:35:37 AM State WAIT
